Whirring Noise from car
Old Apr 4, 2002
EvilTwin's Avatar
EvilTwin is an unknown quantity at this point
Alright....here it goes:
I got my cd player relocated to a new spot, and whenever I turn on my cd player auxillary to listen to DVD audio *watch movies*it makes a weird noise *like a very light static*. When I speed up and turn up the sound, the static noise grows louder as does a whirring noise. I talked to the installer and he says that all aftermarket cd players make the static noise, which I'm not sure is true since I never listened to it through anything other than CD or the FM radio. Can anyone help me with this? I hope I didn't confuse you guys too much. Thanx.
Old Apr 4, 2002
pogi2k1ex's Avatar
pogi2k1ex is an unknown quantity at this point
check the rca cables...sounds like either its not connected all the way or something is interfering with it like a ground wire
Old Apr 4, 2002
EvilTwin's Avatar
Yeah...a friend told me that it was either that or some wire was too thin.
Old Apr 4, 2002
YanYan's Avatar
YanYan is an unknown quantity at this point
do you have subs in your back trunk? if you do, you should check your RCA and power cable to see if they close to each other. They should be seperated.
Old Apr 5, 2002
JDog2001CivicEX's Avatar
JDog2001CivicEX is an unknown quantity at this point
Or it could be that you could've just grounded the dvd player to a non-isolated ground and what you are getting is alternator whine.
Check your grounds, connections, on EVERYTHING that is part of the system.
Joe
Old Apr 5, 2002
sprayed2k1turbo's Avatar
sprayed2k1turbo is an unknown quantity at this point
<< Or it could be that you could've just grounded the dvd player to a non-isolated ground and what you are getting is alternator whine.
Joe
Or you could just leave it whining and tell whoever rides with you that its a SC! (j/k)
Old Apr 5, 2002
ACEM2's Avatar
NytRyder2k2's Son
ACEM2 is an unknown quantity at this point
I think ur problem is that ur ruinning the power cable and RCA cable directly next to each other...seperate the cables, for example. Run the power cable on one side of the car and the RCA on the other side.
Old Apr 5, 2002
Redline01's Avatar
Redline01 is an unknown quantity at this point
If all of the stuff above doesn't work, then go to Radio Shack and buy a groundloop isolater for each RCA cable. That will get rid of the noise.
Old Apr 6, 2002
Ritz's Avatar
Ritz is an unknown quantity at this point
yea listen to 1sickcivic he knows what hes talking about. My car had the same problem so I rewired it myself and ran the power wire on one side of my car and the power wire on the other side it works great now.
Old Apr 6, 2002
Redline01's Avatar
<< If all of the stuff above doesn't work, then go to Radio Shack and buy a groundloop isolater for each RCA cable. That will get rid of the noise. >>
Yup he's right. The electric noise from the power wire will pass though the RCA cables and be interpreted as noise. If you seperate them, the noise will stop. However, some times the altenator will emit noise that will also pass though the Head Unit or the RCA cables. To get rid of this noise, use have to use a Ground-Loop Isolator. It will absorb the ground loops noise and give you a clear signal.
Old Apr 7, 2002
O1Coupe's Avatar
O1Coupe is an unknown quantity at this point
It's your alternator noise, since it increases with increase in RPM. Check your wiring to make sure everything is grounded properly.
ghondavic
Transmission
Apr 12, 2017 09:37 PM
kanin247
Bolt-on Engine Performance
Apr 25, 2015 05:44 AM
Linda0818
Apr 23, 2015 11:30 AM
SSMatey
Apr 13, 2015 06:09 PM
godka0s
Nov 8, 2001 07:16 PM
