car undrivable....
Old Jul 4, 2008
HondaKorn's Avatar
Life is better with 5lug
Exclamation car undrivable....
when camber is set like this and something grinds, im assuming its the tire hitting the struts?? also steering is shitty as well, very undrivable. in was playing around with the settings for my new wheels 17x8.5 +30f.....logical explanation????
Old Jul 9, 2008
Eyger's Avatar
A long winded 7th genr
Eyger has a reputation beyond reputeEyger has a reputation beyond reputeEyger has a reputation beyond reputeEyger has a reputation beyond reputeEyger has a reputation beyond reputeEyger has a reputation beyond reputeEyger has a reputation beyond reputeEyger has a reputation beyond reputeEyger has a reputation beyond reputeEyger has a reputation beyond reputeEyger has a reputation beyond repute
Re: car undrivable....
Um, I'm not an expert, but I think you can only fit a 7.5 wide wheel maximum under there. It also sounds like your offset is too low. Again, I'm not sure, but everything I've seen for the 7th gen is 7.5 width and then like +36 or 38 offset.
Old Jul 9, 2008
TRIZ's Avatar
Wow, I know the pillowball moves, as mine does on my megans, but it looks like its way in to towards the center of the car. Why is that?
Old Jul 9, 2008
02BLKCIVIC's Avatar
Official Rattlesnake Hunter
what the...
Old Jul 9, 2008
tuningmycivic's Avatar
tuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to all
looks like you dialed in a bit too much camber there bro. i would imagine every tire rotation is chewing up the inner surface of your rims and possibly the tires, depending on where it's rubbing. i would be willing to bet it's either the lower spring perch or god forbid your outer tie rod end where the steering arm connects to it. better jack it up asap and take a look.
not to mention that is a really low offset for such wide wheels. i would consider raising the car a bit as well, since you have full coilovers and adjustable pillowball mounts. have fun
Old Jul 30, 2008
trev0006's Avatar
The Video Collector
trev0006 is a splendid one to beholdtrev0006 is a splendid one to beholdtrev0006 is a splendid one to beholdtrev0006 is a splendid one to beholdtrev0006 is a splendid one to beholdtrev0006 is a splendid one to beholdtrev0006 is a splendid one to beholdtrev0006 is a splendid one to beholdtrev0006 is a splendid one to behold
too wide of a tire
Old Jul 31, 2008
HondaKorn's Avatar
i fixed it, rim width was fine and tire size was 215/45.....i just went and got it done by a professional
Old Jul 31, 2008
emjay's Avatar
emjay is a jewel in the roughemjay is a jewel in the roughemjay is a jewel in the roughemjay is a jewel in the rough
^^^^ sumting u shoulda done from the start .. u don't align ur own car lol
Old Jul 31, 2008
HondaKorn's Avatar
now i know hahahaha
usajags84
15
Aug 19, 2015 03:12 AM
ChristinaVHH
May 10, 2015 03:51 PM
JjAnGPeETuL
Nov 8, 2001 06:37 AM
CiViCPrAnInG2k1
Nov 2, 2001 02:49 PM
ImmortalEX
Oct 31, 2001 10:00 PM
