Alternator Fuse Location?
Old May 3, 2008
LVEM2's Avatar
LVEM2 is an unknown quantity at this point
OK, Sorry to sound like a nO0b but where is the alternator fuse located? My battery light is on and i figuered il try that first.. Thanks.....
Old May 3, 2008
Alpha 5's Avatar
Re: Alternator Fuse Location?
It is in the main fuse panel under the hood.
Old May 6, 2008
LVEM2's Avatar
I have gone into the fuse box under the hood, but i do not see a designation for the alternator fuse..
Old May 6, 2008
CraigW's Avatar
Check #4 = 10 Amp in under dash fuse box.
#19 = 80 Amp and # 20 = 40 Amp in under hood fuse box.
Old May 6, 2008
andyman97's Avatar
Turbo Guru
It's just a fuse for the alternator/voltage signal. The main juice to the alternator runs directly off the battery.
Old May 6, 2008
civicsrcool's Avatar
civicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond repute
its in the fuse box under the steering column. there are two tabs you twist and then you can pull off the under dash cover. look for alternator on the diagram and pull it out
roverben
Jan 21, 2019 05:16 PM
jbdewitt
Jun 16, 2015 01:36 PM
Mike Garvey
Jun 7, 2015 07:25 PM
smmahan
Apr 15, 2015 08:17 PM
nrrhgreg
Jan 31, 2002 02:11 PM
