Help, need to change my cam out!!
Old Apr 23, 2008
boonecivic's Avatar
boonecivic will become famous soon enoughboonecivic will become famous soon enough
I need to change my cam back to the stock one. I've never had to change a cam out before, so i was wondering if someone could help me out and guide me thru it. Its probably really easy, but i dont want to mess anything up. So help someone
Old Apr 23, 2008
TRIZ's Avatar
Re: Help, need to change my cam out!!
Download the manual- there is a link at the end of the first post in this thread:
https://www.civicforums.com/forums/7...e-updated.html
Mainly you need to pull the head, and then make sure you use the correct criss-cross unbolt pattern so your dont warp the head. From there you need to remove your valve springs, there is a link to my video DIY in my sig. Then have some assembly lube for the install and repeat the whole process backwards.
Old Apr 24, 2008
boonecivic's Avatar
hey thanks for that link, im gonna have to check it out later today when i get home from work. I notice you have the stage 2 crower cam and the vafc. I have the same thing and it runs like crap and wont idle. Do you also have these problems? that is why i am taking out my cam and putting my stock one in because i am throwing so many codes. are you having any of these problems or had these problems?
Old Apr 24, 2008
TRIZ's Avatar
The stage 2 cam needs the valve spring upgrade from crower, or supertech. Aside from that, you need something to tune it with... vafc2 wont do anything but help set vtec points and monitor AFR. You need to pick up something where you have the ability to change the parameters to fix this- which pretty much boils down to AEM EMS, or Hondata Kpro. It'll run you about 1,000 bucks to pick up either of these- then you need to get it dyno tuned. Making power isnt cheap- go big or go home!!
Old Apr 24, 2008
boonecivic's Avatar
Yep i got the up graded retainers, and im getting the k pro but just wanted to see if where i got my car tuned at did a crappy job. Im going to need the ecu out of the rex for the k pro correct?
Old Apr 24, 2008
boonecivic's Avatar
I mean rsx not rex
Old Apr 24, 2008
TRIZ's Avatar
You can get it from several K series engines i believe- check the hondata website: http://www.hondata.com/kpro.html
Old Apr 25, 2008
Rufus's Avatar
Call Joe at locashracing.com
159
Jul 5, 2015 09:54 PM
Tybonater
Apr 24, 2015 07:03 PM
Myredjonda
Apr 14, 2015 07:00 PM
thesushiboy
Apr 12, 2015 07:40 PM
AnotherDopeStyle
Dec 28, 2001 05:01 PM
