missfire plus crankcase pressure!need help
Old Apr 16, 2008
88honda2000's Avatar
88honda2000 is an unknown quantity at this point
ok i have a 00 civic si with a greddy turbo.i just replaced the head gasket and overhauled the turbo.now just like before i have smoke and missfire.and for some reason the crankcase has enough pressure to blow the dipstick out of the hole.i replaced the pcv valve a few times,but the same crap keeps happening.any ideas?
Old Apr 16, 2008
Boilermaker1's Avatar
Jap-Euro Fusion
Re: missfire plus crankcase pressure!need help
PCV delete.... get the Endyn Catchcan system with the block plugs.
Old Apr 17, 2008
is it hard to install?
Old Apr 17, 2008
Jap-Euro Fusion
If you did a headgasket by yourself and turboed the car.... how hard can anything else be?
Its a couple lines coming out of the back of the block. You swap some fittings.
Old Apr 17, 2008
FoSho's Avatar
FoSho is a glorious beacon of lightFoSho is a glorious beacon of lightFoSho is a glorious beacon of lightFoSho is a glorious beacon of lightFoSho is a glorious beacon of lightFoSho is a glorious beacon of light
Excessive crankcase pressure is pushing oil past the rings, fouling the plugs, causing a misfire.....
This has happened to me twice & I almost lost my motor.....
I'm doing my headgasket at the moment as well. I took the stock pcv valve, drilled it out, & rigged a catch can system. The moisture from my leaky h/g caused the pcv system to clogg up & pressurize the crank case.
It sounds like you're still runing the stock pcv system!
Old Apr 18, 2008
from yur thread and mine i think we are going through the same problem.i just pray i didnt blow any other seals.so what did you use for a catch can?i heard you could use a lufa and an electrical box sealed with rtv.
Old Apr 18, 2008
FoSho's Avatar
True you can. I'm running a Jaz mini catch can from JEGS! Like 30-40 bucks
brash99
Sep 29, 2015 08:42 AM
Bruce2
Sep 27, 2015 08:45 PM
Deebo12
Air Conditioning
Sep 26, 2015 11:08 PM
Michael Durkin
Transmission
Sep 24, 2015 12:35 PM
Bruce2
Sep 21, 2015 08:01 PM
