Location of Vtec Solenoid Valve and Oil pressure switch on 98 Civic
Old Apr 9, 2008
fbruno's Avatar
fbruno is an unknown quantity at this point
I have a 1998 Civic EX with a single overhead cam engine and need to find the location of the solenoid valve and oil pressure switch on the engine.
I have a haynes manual and it only shows the dual overhead cam engine.
Old Apr 11, 2008
lemac's Avatar
lemac will become famous soon enough
Re: Location of Vtec Solenoid Valve and Oil pressure switch on 98 Civic
Hope this helps
Old Apr 15, 2008
BoneStOck_176's Avatar
BoneStOck_176 is an unknown quantity at this point
and the location of the solenoid applies to a 00 SOHC as well... Right!!?
Old Apr 15, 2008
i dont think the shape changed much over the years
Old Apr 21, 2008
lambada's Avatar
lambada is an unknown quantity at this point
Is it any different on a B16A2 engine? I can't seem to find one? It should be towards the back of the engine bay right?
Is it true that this solenoid should be heard clicking when the engine is revved even if it is in neutral?
Old Apr 21, 2008
nope, the solenoid will not engage just revving in neutral. it should be bolted somewhere to the cylinder head. if its not, then you dont have vtec.
Old Aug 11, 2010
kurtdaniel's Avatar
kurtdaniel is an unknown quantity at this point
Originally Posted by lemac
Hope this helps
i have the same inquiry..good thing i found this thread..this is very helpful..
Old Jan 17, 2011
emicha's Avatar
emicha is an unknown quantity at this point
Who sells just the oil pressure switch?
Old Jan 18, 2011
delete edit
Xuhme
21
Aug 7, 2023 03:40 PM
LionSpratt
Jan 29, 2017 11:07 PM
usajags84
May 10, 2015 08:11 AM
LionSpratt
Apr 26, 2015 01:02 PM
Gunner
Engine DIY
Oct 6, 2012 12:37 PM
