Which coilovers? Tein SS-P or Flex?
Hey guys,
I'm a NOOBIE and I have couple of questions concerning the Tein SS-P (DSA22-2USS1) or Flex (DSA22-6USS1). I apologise for asking all these questions. This will be for my 2005 Civic (click on link for pix)
https://www.civicforums.com/forums/1...ml#post4294087
1.) I've heard that the Flex can squeak from time to time depending on road conditions. Not aware of any noise issue with SS-P. Any comments?
2.) What is the maximum ride height drop (front & rear) for both of them?
3.) Any reliabilities issue?
4.) I know that a rear camber kit is needed? Any particular brands recommended?
5.) The SS-P uses a one-strut design (spring travel is relative to ride height) but for the Flex, the spring travel and ride height are independent from one another. Anybody ever have any problems in the SS-P with excessive drop but harsh ride (not enough spring travel).
6.) Can you feel (bum-o-meter) the actual difference between the softest setting of the Flex (#16) and the hardest setting of the SS-P (#1)? Or is there some kind of overlap?
Sorry for all the long list, but I'm a a NOOBIE and any help will be greatly appreciated.
Vee
Vee
Last edited by veeru83; Mar 8, 2008 at 02:01 AM. Reason: need help on Tein = more questions
Re: Which coilovers? Tein SS-P or Flex?
most people here have the SS. the flex i think one one guy had and its mostly for racing. i dont think its that great for daily driving.
I would recommend the super street. I've put 60k on my type flex, its too much for everyday driving. The suspesion is much to stiff even on the softest setting with the least amount of pre-load. If you are using the car just for racing the flex is great. I have ridin in alot of lowered cars but nothing half as stiff as the tein type flex. NOt for everday use!
Hey guys,
1.) I've heard that the Flex can squeak from time to time depending on road conditions. Not aware of any noise issue with SS-P. Any comments? I have never heard of either squeaking.
2.) What is the maximum ride height drop (front & rear) for both of them? It's on Tein's website
3.) Any reliabilities issue? No, they are good quality
4.) I know that a rear camber kit is needed? Any particular brands recommended? SPC or ingalls
6.) Can you feel (bum-o-meter) the actual difference between the softest setting of the Flex (#16) and the hardest setting of the SS-P (#1)? Or is there some kind of overlap? Not really
Vee
Vee
The World Is Yours!
get flex... since youll always wonder..if you have cash flow..why didint i spend the extra money... buy what you want initially. and you wont be dissappointed!
Do you have any reason for getting the flexes over the SS-Ps? If you don't need the adjustability, then stick with the SSs. Why do you need a camber plate?
Couple more questions:
1.) I'm looking at the Skunk2 rear camber kit (516-05-0510). Will it fit my 05 Civic EX sedan?
2.) I'm hoping for a drop height of about 2.5" (at lowest ride height setting), is that possible with the Tein SS?
3.) Is the pillow mount necessary? The SS doesn't have it but I checked on the other posts and some say that it's not that important (only helps with camber adjustment). Any other comments?
Thanks.
Vee (Thailand)
I heard it's better all around. I don't plan on on tracking it, more of a street race kinda thing. then stick with the SS, there is no need for the flex and they are going to be very stiff on the street
In Thailand, the Flex is not officially sold and must be imported from Japan, so the price is double the SS. If it weren't that much different, I'd go for the Flex.
1.) I'm looking at the Skunk2 rear camber kit (516-05-0510). Will it fit my 05 Civic EX sedan? yes.
2.) I'm hoping for a drop height of about 2.5" (at lowest ride height setting), is that possible with the Tein SS? No. And you don't want to drop that low. Although dropping low "looks cool" 2.5" is really low. You don't want to go much beyond 1.5-2.
It isn't important. If you aren't racing, then you don't need extreme front camber
Thanks.
Vee (Thailand)
Thanks.
Vee (Thailand)
i was stuck in the same dilema this past summer and ended up getting the flex cuz i knew this way i couldnt regret it. Cost a bit more but is a blast to drive. Not going to lie i cant even tell the difference between the softest and hardest setting because either wya you feel EVERY bump in the road. Personally i can live with it becuase the car is so responsive and you can really feel what the car is doing going around corners and such. I tracked it a couple times and that is my only suspension mod for now except i guess good tires and its completely ridiculous how big a difference it makes in the transitioning from one corner to the next and how much smoother it is around corners nad holds. As for drop, i still have a solid half inch to drop and my tires are already flush with the fender so as for dumping believe me you will be fine with the flex.
Slowest 7thgen in the GTA
I just came back from a shop. I just purchase the SSP about an hour ago.
I guess get the flex or SS are personal opinions. Everyone likes something different, but I would assume quality is the same, since its Tein.
Thanks robbclark1 for all the info. I think I'm swaying towards the SS now, but wait..............
I found a sweet deal for a Tein MonoFlex DC5 on Yahoo Auction Japan. Current price is $420, but there's about 4 days left (as of 15/03/08). What do you guys thing? Overboard? Will a DC5 even fit my 05 EX Civic Sedan? Advise please.
phuviano, it's been 2 days since you had the SSP on, how's the first impression?
Go with the ss-p you won't regret it especially if your not tracking. I put em on mine about a month ago ride is rougher than stock but you get used to it, you'll notice a huge improvment in handling and cornering.
Hey guys,
I'm a NOOBIE and I have couple of questions concerning the Tein SS-P (DSA22-2USS1) or Flex truck part (DSA22-6USS1). I apologise for asking all these questions. This will be for my 2005 Civic (click on link for pix)
Vee
Vee
TheRiddicles
Sep 21, 2015 01:28 AM
