Name brand vs Generic Strut bars
Old Mar 25, 2008
qijian's Avatar
is there a BIG difference between the two? or is it the same thing just with a name on it? Because im looking into getting a rear strut upper bar and there is a big price difference between the two. Is it worth it? or for looks?
Old Mar 26, 2008
civic-driver's Avatar
civic-driver has a reputation beyond reputecivic-driver has a reputation beyond reputecivic-driver has a reputation beyond reputecivic-driver has a reputation beyond reputecivic-driver has a reputation beyond reputecivic-driver has a reputation beyond reputecivic-driver has a reputation beyond reputecivic-driver has a reputation beyond reputecivic-driver has a reputation beyond reputecivic-driver has a reputation beyond reputecivic-driver has a reputation beyond repute
Re: Name brand vs Generic Strut bars
well it depends on a few things. the only real differences are a single piece strut bar versus a multi piece. The solid single piece bars like the neuspeed front upper bar are better in comparison to most strut most multi piece bars. The multi piece bars have two strut mount brackets that are connected by a bar with a bolts connecting every thing, this design allows the bolts connecting things to act like hinges to an extent. Where there isnt much movement in these "hinge-like" areas, its still not as solid as the one piece that basically connect the struts directly.
So what im getting at is that its not necessarily the name brand difference rather the design. Granted the name brand are usually of better quality materials and fit better.
Im going to assume your looking at a Cusco rear upper versus a megan racing rear upper (Corsport is made by megan). Between the two i dont think you will see much of a difference between the two just because the rear uppers in general dont make a huge difference and i think they are both multi piece bars. so in short i would say that you won't be needing the high end bar unless you do shows. For the record i dont think there is a solid rear upper made for our cars.
Last thing i have to say though is do you have other suspension parts as well? I ask because this upgrade is pretty low on the list ( if not last) of things that will make a big difference in handling. I would say new springs with matching struts or coilovers would be a good first choice then some nicer sway bars and a front upper strut bar. After that you could worry about stiffening the rear lower and rear upper.
Thats just my thoughts on the best route to do a suspension though. You can do what you want . Sorry if i over explained this a little but it was for your benefit and the people that are usually too quiet to ask questions and such. Hope this helps. I believe there is more info on the subject in the suspension FAQ but i honestly havent read it lol.
Old Mar 26, 2008
Envy's Avatar
Diamond Member
Envy is a glorious beacon of lightEnvy is a glorious beacon of lightEnvy is a glorious beacon of lightEnvy is a glorious beacon of lightEnvy is a glorious beacon of light
idk. ill sell you a megan racing one for $50 shipped! brand new!
Old Mar 26, 2008
qijian's Avatar
hmm well i have blues + s techs and a front strut bar already and a dc lower tie. and probably getting a rsx type s sway bar soon. the reason i wanted a rear upper strut was because im having crunk noises coming from the right rear when i make sharp left turns and some people said the noise is due to the body flexing and a mere upper rear strut would eliminate that noise. so yeah (=
Old Mar 26, 2008
same as the megan but a little cheaper: http://www.corsportusa.com/store/cat...roducts_id=381
as far as the noise being from body flex im not sure i have never heard of that before. im not sure but i would think that is from something being put back together incorrectly. i'm not an expert be any means though. maybe someone that has had a similar problem or a better answer will chime in.
Old Mar 26, 2008
MrXclusivE's Avatar
MrXclusivE is a glorious beacon of lightMrXclusivE is a glorious beacon of lightMrXclusivE is a glorious beacon of lightMrXclusivE is a glorious beacon of lightMrXclusivE is a glorious beacon of lightMrXclusivE is a glorious beacon of light
I think that noise is from the bushings man, save your money to get the bushings done
Old Mar 26, 2008
cinaibur's Avatar
cinaibur is just really nicecinaibur is just really nicecinaibur is just really nicecinaibur is just really nicecinaibur is just really nice
the noise probably isn't body flex. there is very minimal body flex in the rear
Old Mar 26, 2008
sl33pyriceboi's Avatar
i hvea a neuspeed front strut bar... makes a big diff when i forgot to install it after i installed my suspension...lol had to put it bak on.
Old Mar 26, 2008
qijian's Avatar
oh hah ic, thanks guys for the input. where is the bushing that i need to get done maybe?
Old Mar 26, 2008
chkolny's Avatar
chkolny will become famous soon enoughchkolny will become famous soon enough
i have the same sound, im curious what the hell it is, mines a creaking if i take turns too fast.
Old Mar 26, 2008
Mr_Plenty's Avatar
Mr_Plenty is a jewel in the roughMr_Plenty is a jewel in the roughMr_Plenty is a jewel in the rough
check the bearings in the rear?
Old Mar 26, 2008
Mr_Plenty's Avatar
and bushings for sure they usually squeek and creak and clunk when there done
Sep 26, 2023 06:44 PM
brags
46
Jan 7, 2016 09:39 PM
srtlat
Jul 17, 2015 11:53 PM
fordover
Jul 11, 2015 09:10 PM
