Battery relocation help!!
Old Jan 3, 2008
David D's Avatar
David D is an unknown quantity at this point
I would like to relocate the battery in my 2001 Civic EX to the trunk, so I can get some extra room under hood for some stuff i want to do... I know you have to use a heavy gage cable like a 4 ga ...i think.. and a fuse of some sort....
any info or insight on this subject would be greatly appreciated.
- David
Old Jan 3, 2008
beadebaserr's Avatar
beadebaserr will become famous soon enoughbeadebaserr will become famous soon enough
Re: Battery relocation help!!
this is all i did, probably a better solution but i've had zero problems.
cut the ring terminal off your positive wire, get more than enough power wire, 4ga would be fine, get an inline fuse block, hook it up to the positive you cut and your new wire, then just ground the battery in the trunk on a good spot. make sure you scuff the paint off so you have a good ground, and if you have some wire exposed on the fuse block ends, wrap some butyl around it or something else that will keep it waterproof and not exposed.
Old Jan 3, 2008
speedfoos's Avatar
I basically did the same thing but just ran my wire from where that positive battery cable tapped into the main harness. Either way it's the same concept.
It was really easy since I already had 4 ga. running to the trunk for my amp to begin with, plus the ground was already there as well.
Old Jan 3, 2008
yeah, it's really an easy process. don't waste 120 bucks on a battery relocation kit pleeeeease. you'll kick yourself in the head afterwards. you can get a marine battery box that serves just fine for like 25 bucks at harbor freight.
robjcivic
Mar 12, 2017 12:10 PM
haloway13
Nov 6, 2015 10:43 AM
Bricoleur
Sep 9, 2015 12:23 PM
vImpostor
Vancouver
Sep 8, 2015 08:08 PM
msaeger
Sep 2, 2015 08:47 AM
