noise from suspension, explanation w/ pic inside
Old Nov 28, 2007
CIVIC X3's Avatar
CIVIC X3 is on a distinguished road
okay...finally i got a pic of my front tein basic. wen i drive, it doesnt matter if the weather is cold or hot, going over small or big bumps, it keeps making this clicking sound.
i actually greased arrow "A" to see if the noise would go away but it didnt.
arrow "B", under that black piece, it has a white plastic piece that is attach to the shock and can move freely. does that inside part needed to be grease?
as for arrow "C", theres a rubber round piece jus right under the spring. would greasin the top and bottom of it help?
arrow "d", could that be a problem thats causing the clickin noise?
arrow "E", the bolt is tighten, as well as the top three bolts. i read a couple of thread sayin that loosen bolts can cause the clickin noise/ or any noise to the suspension, so that was actually the first thing i did; i made sure everything was tight.
Old Nov 28, 2007
Mr_Plenty's Avatar
Mr_Plenty is a jewel in the roughMr_Plenty is a jewel in the roughMr_Plenty is a jewel in the rough
Re: noise from suspension, explanation w/ pic inside
Ok i'm not sure about the coilovers clicking, they should squeek really. the only time my suspension clicked was when the rotor screws were loose. check those...
Old Nov 29, 2007
jamis33's Avatar
You Stay Classy, San Diego
mine squeak how do you get rid of the squeaking or is it just part of havin tein coilovers???? Mine isnt as much a squeak as it is a chirp like a bird or somethin. I cant figure out how to get rid of it. I just turn my subs up louder hahaha.
Old Dec 6, 2007
MBison's Avatar
MBison is just really niceMBison is just really niceMBison is just really niceMBison is just really nice
it could be a worn strut mount. i've just ordered some kyb ones.
Old Dec 7, 2007
CIVIC X3's Avatar
will the kyb ones fit for the tein basic? or its universal?
Old Dec 7, 2007
bakertime's Avatar
bakertime is a jewel in the roughbakertime is a jewel in the roughbakertime is a jewel in the rough
I've got Ksports that used to always bind (the spring wouldn't turn). The squeeking you're all hearing may also be cause by that. I tried grease, nylon washers, all kind of stuff and ended up finding these:
https://www.civicforums.com/forums/4...sound-fix.html
Old Dec 7, 2007
MBison's Avatar
they're universal, and heres the link: http://cgi.ebay.com/ebaymotors/KYB-S...spagenameZWD1V
keep in mind that it could be something else, but im definitelly swapping my stocks with these hoping it will take care of the clunking noise im experiencing when turning the wheels at a low or no movement at all.
hope this helps.
Old Dec 8, 2007
CIVIC X3's Avatar
thanks MBison for providing the link. +1 rep. ALso bakertime where would i install this part by lookin at my pic? O_o letter "A" or "C"....seems lik in your thread its "C".
Old Dec 8, 2007
MBison's Avatar
Thumbs up Re: noise from suspension, explanation w/ pic inside
thanks buddy. im just hoping that the mounts will solve the noise issue. good luck!
Old Dec 10, 2007
guthriebarrett1's Avatar
guthriebarrett1 is an unknown quantity at this point
i have the same noise, but i think when the lowering was done, the bushing's weren't installed, is it more of a click? or more vibration...
Old Dec 10, 2007
MBison's Avatar
in my case its clunking and no vibration, at least i have not noticed any.
Old Dec 29, 2007
MBison's Avatar
update: replacing the oem strut mounts with kyb ones took care of the noise coming from the struts that i used to experience, so i highly recommend doing that. that was one of the best investments that i've done as for the car suspension. its worth every penny. hope this helps.
Old Dec 30, 2007
CIVIC X3's Avatar
hmm, helps greatly. havent taken care of my problem yet. been raining like crazy. how much did the mounts cost total?
Old Dec 30, 2007
speedfoos's Avatar
Likewise man. Been needing to replace mine as well. Rep to MBison applied.
Old Dec 31, 2007
MBison's Avatar
it cost me nearly $100, but no more. great suspension upgrade!
Old Jan 1, 2008
MBison's Avatar
here's the best deal on them straight from rsautoparts.com with free shipping: http://www.rsautoparts.com/Store/Sea...t=1&key=SM5403
i can honestly say that the mounts greatly reduced the noise in the front, however, it did not totally eliminate it. i suppose its because of the stress that is put on the aftermarket struts and springs, so i think its normal. what do u guys think?
Old Jan 1, 2008
MBison's Avatar
great stuff. the kyb strut mounts have the bearing made of teflon and that works pretty good. anyway, thanks for the link.
rovafa2002
Sep 28, 2015 06:57 PM
15EXCoupe
Jul 30, 2015 12:59 PM
17
Jul 23, 2015 11:48 PM
f575gtc
Transmission
Jul 13, 2015 09:16 PM
1khilari
Jul 9, 2015 08:12 PM
