Would this busted part cause my trans problem?
Old Nov 18, 2007
roncking's Avatar
roncking is an unknown quantity at this point
I have a '99 civic that's giving a P1768 error code. It's not low
on transmission fluid.
The D4 indicator on the dash blinks on and off, and the car will move,
but it feels like the transmission is slipping badly, so much in fact,
that I have to get a running start for it to climb upon the little car
ramps I use when I want to look under a car! I looked up under the
front of the car, and there is an electrical connector on the front of the transaxle that has broken off. I wonder what this device is that it is attached to, and could it be causing my problems.
I'm attaching a picture of a broken part on my transaxle. Can anybody
tell me what it is, and will the fluid leak out if I remove it?
Old Nov 19, 2007
ultimatetuner10's Avatar
Technical Assistant
ultimatetuner10 has a reputation beyond reputeultimatetuner10 has a reputation beyond reputeultimatetuner10 has a reputation beyond reputeultimatetuner10 has a reputation beyond reputeultimatetuner10 has a reputation beyond reputeultimatetuner10 has a reputation beyond reputeultimatetuner10 has a reputation beyond reputeultimatetuner10 has a reputation beyond reputeultimatetuner10 has a reputation beyond reputeultimatetuner10 has a reputation beyond reputeultimatetuner10 has a reputation beyond repute
Re: Would this busted part cause my trans problem?
circle the part on the pic and try to get a bigger shot..i cant even tell where that is
Old Nov 19, 2007
roncking's Avatar
I found out that its the linear solenoid. I'm going to replace it, and hope that fixes my problem! Thanks.
Old Nov 19, 2007
speedricerx's Avatar
speedricerx is a glorious beacon of lightspeedricerx is a glorious beacon of lightspeedricerx is a glorious beacon of lightspeedricerx is a glorious beacon of lightspeedricerx is a glorious beacon of lightspeedricerx is a glorious beacon of light
your welcome.
usajags84
15
Aug 19, 2015 03:12 AM
cruisers10
May 12, 2015 10:46 PM
shindrome
Exterior
May 5, 2015 02:50 PM
davidpaustin
Apr 29, 2015 02:23 PM
Russps
Nov 8, 2001 02:00 AM
