i need help fast
Old Oct 4, 2007
01candycivic's Avatar
01candycivic is a jewel in the rough01candycivic is a jewel in the rough01candycivic is a jewel in the rough
i need help fast
ok so i have to get this tie rod out of the strut
i unbulted it but the damn thing will not pop
its stuck and i do not remember how i got it off last time.
i need help fast i have a bout a hr to get it off and put back together
Old Oct 4, 2007
Alpha 5's Avatar
Re: i need help fast
Whack it with a hammer.
Or use a tie- rod separator. This can be purchased for less than $10 at an automotive parts store.
Old Oct 4, 2007
Boilermaker1's Avatar
Jap-Euro Fusion
quickest way.... take a hammer, bang on the arm until it pops loose.
Old Oct 4, 2007
some auto store rent the tie rod separator. its like a tuning fork you hammer and it slowly wedges it apart.
Old Oct 4, 2007
greeen01civic4d's Avatar
dont hit the bottom of the bolt with a bare hammer, it will strip the bolt, all u gotta do is put a piece of wood inbetween em, or hit the arm with the hammer till it pops, but its up to u
Old Oct 4, 2007
bomerman19's Avatar
bomerman19 has a reputation beyond reputebomerman19 has a reputation beyond reputebomerman19 has a reputation beyond reputebomerman19 has a reputation beyond reputebomerman19 has a reputation beyond reputebomerman19 has a reputation beyond reputebomerman19 has a reputation beyond reputebomerman19 has a reputation beyond reputebomerman19 has a reputation beyond reputebomerman19 has a reputation beyond reputebomerman19 has a reputation beyond repute
if you put the nut on it so it is flush with the bottom of the bolt and hit it with a hammer it won't bind the threads on the bolt. Basicly make sure you are hitting the nut and not the bolt, other wise you will screw up the threads. It will take a couple of good wacks with the hammer to get it loose. That one is a pain I had the same one stuck on me to.
Old Oct 9, 2007
thanks guys. so i had to get a new tie rod end. i hit the threads lol.. i needed a new one anyway...
Old Oct 9, 2007
bakertime's Avatar
bakertime is a jewel in the roughbakertime is a jewel in the roughbakertime is a jewel in the rough
Too late now, but what worked for me was to use the oem jack with a piece of wood. Put pressure on the bottom of the bolt with the jack(wood in between) and then once there is a lot of pressure, give the arm a few good whacks and it frees it right away. Sorry I didn't see the thread sooner...
solarpunk70
Apr 12, 2016 11:43 AM
IronFist
Sep 25, 2015 07:13 PM
meicalnissyen
Sep 25, 2015 12:12 AM
junkyardguy
20
Sep 6, 2015 10:07 PM
jonwalden68
Aug 27, 2015 12:07 PM
