Transmission problems. Help plz, lol!
Old Sep 17, 2007
Cram's Avatar
Cram is an unknown quantity at this point
Car: 2001 Civic EX Coupe
Engine: little Inline 4 w/ V-Tec (WHOOP WHOOP, V-tek, yo!)
Transmission: Automatic
Story: Ok, so I was driving down the street today like normal, and when the car tried to shift into 2nd, it simply slipped into neutral and the engine just revved. I pulled off the main street and tried to figure out what was wrong. The car would drive fine in first, but when it went to go to second, it would not go, and thus, it would not go back into first so I simply rolled to a stop.
I tried putting the car in reverse, and that worked the first time, then I tried putting it in drive and it wouldn't work.
I sat there for a while, then put it in Drive again and it started to go. I made it to a better spot to pull over and stopped and called a friend to come pick me up.
When my friend arrived, I told him I would have him follow my car and see if I could drive it a little further to a shop or something. However, this time the car would not move when it was in reverse, D, or D2, or D3
Sooo, I'm a total idiot when it comes to cars basically. The car isn't modified in any way, so it's not like I F'd up installing anything.
Does this sound like a serious issue with the transmission, or is it perhaps just the fluid? I'm really at a loss for what it might be and I'd like to have some idea before I take it to some place that tries to charge me $1500 for a $15 fix.
Any help is appreciated. Really good advice that saves me money will result in an adoption!
Old Sep 17, 2007
primetime's Avatar
primetime is an unknown quantity at this point
Re: Transmission problems. Help plz, lol!
I'd check the transmission fluid first
Old Sep 17, 2007
eekicks's Avatar
eekicks is an unknown quantity at this point
I would check the fluid but hate to tell you that I dont think that is the issue. Do you drive it hard (burnouts, squeak tires and such)? IF you do you may have done some internal damage which is going to be expensive to fix
Old Sep 17, 2007
speedricerx's Avatar
speedricerx is a glorious beacon of lightspeedricerx is a glorious beacon of lightspeedricerx is a glorious beacon of lightspeedricerx is a glorious beacon of lightspeedricerx is a glorious beacon of lightspeedricerx is a glorious beacon of light
seems like auto trannys of 01-02 civics are known to go bad.
how many miles do u have on your car?
have you ever changed the tran fluid before?
search?
Old Sep 17, 2007
your trans is garbage now. honda knows theres a defective clutch that wears out fast and then causes the whole thing to go. so call up corporate, be nice, and maybe they will offer to pay for some of the new one.
Old Sep 17, 2007
Devani's Avatar
Devani has a reputation beyond reputeDevani has a reputation beyond reputeDevani has a reputation beyond reputeDevani has a reputation beyond reputeDevani has a reputation beyond reputeDevani has a reputation beyond reputeDevani has a reputation beyond reputeDevani has a reputation beyond reputeDevani has a reputation beyond reputeDevani has a reputation beyond reputeDevani has a reputation beyond repute
give us more info so that we could help you...
milage on the car? changed trans fluid at all?
Old Sep 17, 2007
So.Ill.EM2's Avatar
Ultra-Platinum Super Bonus Member
So.Ill.EM2 is just really niceSo.Ill.EM2 is just really niceSo.Ill.EM2 is just really niceSo.Ill.EM2 is just really nice
*sniff sniff* do you smell that??
smells like a manny tranny swap to me...
Old Sep 17, 2007
or burning clutches lol.
Old Oct 8, 2007
Em2onCPRs's Avatar
DU MA Con Cac
Em2onCPRs is an unknown quantity at this point
^^^^ i called corporate these guys told me to go to my local dealer ask for inspection on the defect. i called my local honda they were going to charge me $180 just to inspect it. Im on the same boat 2001 auto tranny are trash!
Old Oct 8, 2007
PitchBlack's Avatar
PitchBlack is just really nicePitchBlack is just really nicePitchBlack is just really nicePitchBlack is just really nice
its done man...especially if you are throwing a gear ratio incorrect code. Mine did the exact same thing before it ****...good luck getting a new one...throwing a manual in is cheaper than getting another crappy auto.
Old Oct 9, 2007
sikomaniac's Avatar
sikomaniac is an unknown quantity at this point
word on that. this problem just happened to my roommate this week. she has a 2001 4DR AT. she's at 116,000 miles and not the best at maintenance, but having a tranny go out suddenly is a pretty serious problem. best thing you can prob do is just swap in another tranny. she said her bill is gonna run $2900. internet research shows this is not an uncommon problem. surprising coming from Honda.
i wonder if poor maintenance could be a factor? otherwise i don't know why there hasn't been a lawsuit or recall yet. don't forget to change that timing belt to avoid other problems. hope you catch a break somehow. good luck!
Old Oct 10, 2007
Em2onCPRs's Avatar
DU MA Con Cac
^^^^ it is a common problem for automatics, especially for automatics ranging from 2001-2002
SimpleUser
Apr 24, 2021 02:54 AM
Dangerousjordan
Jul 30, 2015 11:19 AM
breanna_17
Jul 21, 2015 04:01 PM
f575gtc
Transmission
Jul 13, 2015 09:16 PM
jody501
Jul 10, 2015 11:01 AM
