i need help fast
i need help fast
ok so i have to get this tie rod out of the strut
i unbulted it but the damn thing will not pop
its stuck and i do not remember how i got it off last time.
i need help fast i have a bout a hr to get it off and put back together
Re: i need help fast
dont hit the bottom of the bolt with a bare hammer, it will strip the bolt, all u gotta do is put a piece of wood inbetween em, or hit the arm with the hammer till it pops, but its up to u
if you put the nut on it so it is flush with the bottom of the bolt and hit it with a hammer it won't bind the threads on the bolt. Basicly make sure you are hitting the nut and not the bolt, other wise you will screw up the threads
. It will take a couple of good wacks with the hammer to get it loose. That one is a pain I had the same one stuck on me to.
. It will take a couple of good wacks with the hammer to get it loose. That one is a pain I had the same one stuck on me to. Re: i need help fast
Too late now, but what worked for me was to use the oem jack with a piece of wood. Put pressure on the bottom of the bolt with the jack(wood in between) and then once there is a lot of pressure, give the arm a few good whacks and it frees it right away. Sorry I didn't see the thread sooner...
solarpunk70
Apr 12, 2016 11:43 AM
IronFist
Sep 25, 2015 07:13 PM
meicalnissyen
Sep 25, 2015 12:12 AM
junkyardguy
20
Sep 6, 2015 10:07 PM
