Central Locking and Head Unit not working, plz help
Old Sep 21, 2007
renesis's Avatar
renesis is an unknown quantity at this point
Hi,
I was changing my head unit, it was working then i turned the car off and then back on, then the head unit wouldn't turn on. I then changed it back to the stock HU and then this wouldnt work either. I then attempted to lock the car and then the central locking wasnt working, both through the button and using the key only locks the door its put into none of the others.
The head unit i was using was an eclipse, and i used a wiring harness.
I don't know what to doo!
Please help anyone! =)
Thanks
Lukas
Old Sep 21, 2007
CraigW's Avatar
Re: Central Locking and Head Unit not working, plz help
Check "back up" fuse in under hood fuse box.
Old Sep 21, 2007
greeen01civic4d's Avatar
good call, thats what i would say as well^^
Old Sep 21, 2007
artnsx's Avatar
artnsx is on a distinguished road
if that doesn't work there are some more fuses under the kick panel inside the car. Whenever something isn't working for me electrically, I've usually shorted out a fuse in there. I've never figured out which fuse does what but i just keep checking until i've found a burnt one.
Old Sep 21, 2007
renesis's Avatar
Yeah i had a feeling thats what might have happened.
I've never changed a fuse in a car before, is it relatively difficult or should i go to a service place.
is there a specific fuse i should look for and where would i get a new fuse from? just any Car accessories shop?
Thanks alot for quick reply
Old Sep 22, 2007
CraigW's Avatar
The fuses rating is marked on the top face you will see when cover removed(it is either 10 or 15 amps) replace it with whatever was in place to start with, never larger.
The fuse pulls straight up and out.
There are spare fuses in both the under-hood and under-dash fuse boxes.
Old Sep 22, 2007
there are a few years of civic where the keyless entry is tied to the stock deck. so if you wanted aftermarket deck, you would have to keep the stock one hooked up too
Old Sep 22, 2007
renesis's Avatar
My civic is a 2005 australian model. Apparantly the aust. models dont require the stereo in for the central to work from what ive 'heard' but who knows.
Sorry to be a pain, but this is a photo of my fuse box, can you point out which ones are spare and which ones i should look at if possible =). (It is the bonnet fuse box [although im sure you could all tell that hehe])
I want to put the eclipse deck back in but will only do so once I know whats wrong with everything else.
Thanks heaps!!
Old Sep 22, 2007
CraigW's Avatar
The "back up" fuse is # 9 = 10 Amp.
The spare 10Amp is in the picture to the right, It is red fuse near the three yellow fuses oriented differently. The lid of the box has diagram underneath.
Old Oct 2, 2007
renesis's Avatar
awesome thanks alot for the help. it was the backup fuse, easily fixed! =D
Thanks again
Old Oct 15, 2007
2k1_Toaster's Avatar
2k1_Toaster will become famous soon enough
What if it isnt the backup fuse?
I havent changed anything in my car, but for some reason tonight my remote wouldnt unlock or lock the car. It would flash my headlights correctly so the signal is getting there, but not do anything to the locks.
Also from inside the car, the lock switch does make a click sound, but does not move the lock (either side) up or down.
I checkup the backup fuse as well as the fuse inbetween the headlight fuses specifically labelled for the doors and they look perfect. Not burned, browned r anything. I could understand a fuse going when changing something but this is a little odd.
What would the next thing be to check?! I can lock/unlock using the key in the door cylinder if that matters.
darwin-t
Apr 18, 2015 09:29 PM
mugenca
Apr 16, 2015 12:15 AM
mwwhonda
Dec 5, 2001 10:52 AM
supercivic01
South
Nov 30, 2001 11:27 AM
PimpBot5000
Nov 26, 2001 07:15 PM
