b16/b18 and h22a
Old Aug 10, 2007
00civicmag's Avatar
00civicmag is an unknown quantity at this point
b16/b18 and h22a
This may be a dumb question, but why do i hear more about b16 and b18 swaps than h22a swaps? i know the h22a has like 30-40 more hp so why bother with a b18?
Old Aug 10, 2007
DsevenEm2's Avatar
This is Myspace
Re: b16/b18 and h22a
becuz they swap in easier than the H and theyre cheaper.
Old Aug 10, 2007
(physical) size considerations and cost
Old Aug 11, 2007
TRIZ's Avatar
While I dont know about the H series as well- you can build the **** outta the B series.
Old Aug 12, 2007
1sykcivic's Avatar
RHCP0801 is my hero
1sykcivic has a reputation beyond repute1sykcivic has a reputation beyond repute1sykcivic has a reputation beyond repute1sykcivic has a reputation beyond repute1sykcivic has a reputation beyond repute1sykcivic has a reputation beyond repute1sykcivic has a reputation beyond repute1sykcivic has a reputation beyond repute1sykcivic has a reputation beyond repute1sykcivic has a reputation beyond repute1sykcivic has a reputation beyond repute
H series burn oil, dont respond well to mods kinda like our crappy d17s
Old Aug 12, 2007
cinaibur's Avatar
cinaibur is just really nicecinaibur is just really nicecinaibur is just really nicecinaibur is just really nicecinaibur is just really nice
tranny sucks too. if i was doing an h22 swap, i would definately do the hybrid swap with the b series tranny.
Old Aug 12, 2007
beadebaserr's Avatar
beadebaserr will become famous soon enoughbeadebaserr will become famous soon enough
tranny sucks, harder swap, weak bottom end.
Old Aug 17, 2007
killercd21's Avatar
killercd21 is an unknown quantity at this point
is there anything Bad about doing a H22a motor and tranny swap with a Turbo into a 1994 Honda Civic CX Hatchback ?
Old Aug 18, 2007
ESK1k20A2's Avatar
ESK1k20A2 will become famous soon enough
save some money and get a K20/24
Old Aug 18, 2007
TemjinX2's Avatar
h-series is a larger engine so you have a higher chance of losing your ac and ps. B-series has better internals and responds a lot better to boost.
The H-series has a nice amount of torque if you want to stay NA.
If you want to go boost then go b-series.
Old Aug 18, 2007
87_Si's Avatar
87_Si will become famous soon enough87_Si will become famous soon enough
I also believe that there is a weight difference in that the H22 weighs more (30 lbs or so). BUT they can be fairly fast as this clip shows.
http://www.youtube.com/watch?v=auVWMJ2R0E0
I agree with Temjin though... B-Series = BOOST-Series LOL.
Old Aug 18, 2007
killercd21's Avatar
Well i already have the H22a Motor, Transmission, and T4 Turbonetics Turbo-Charger in the Hatch... and i was wondering if there should be anything i should look out for... i keeping the boost range at about 4-8psi... is that ok ?
Old Aug 18, 2007
TemjinX2's Avatar
just make sure its tuned right with a hondata. A tuned car at 8psi is more reliable then a untuned car at 2psi.
Old Aug 19, 2007
87_Si's Avatar
If I remember a stock H22 can handle around 12-14 psi if tuned right, but much more then that and even AT that level you should think at least about sleeves. That also depends on if it's closed or open deck. Which H do you got in there?
Old Oct 11, 2007
jweb42055's Avatar
jweb42055 is an unknown quantity at this point
Do you guys ever have a problem with your suspension, when your placing a larger motor in. I've got a problem with my b18, the suspension is lower on the drivers side of the car. I was wondering if this is just the shitty springs i've got in there. I was thinking i should throw si springs in.
Old Oct 11, 2007
TemjinX2's Avatar
the left side of the car is always heavier then the right side. Both the engine and driver both sit on the left side of the road. Just get coil overs and it'll fix the uneveness.
Old Oct 11, 2007
02civicg5's Avatar
02civicg5 will become famous soon enough
well the h22 has weaker rods for turboing. i noe a few things bout the h22. sure the tranny is weaker. but u can also swap the h23 or f22 tranny into it. the f and h series trannies are interchangeable. the f22 tranny has longer gears which give a betta response to the h22. also the h22 makes a great NA project. although its tru that the h22 does not responde well wit bolt ons. i feel like the h22 is a better motor then the b series. just my personal opinion. the h22 was meant to pull a much heavier car which is the prelude. just imagine it on a lighter car like th civic.
Old Oct 11, 2007
TemjinX2's Avatar
i thought the f22c and f20c are not interchange able with the f22 or h22's since the f22c's resemble more to the k series engine.
I think B's are better because of the greater aftermarket support and its geared for more high end power, especially if your going boost.
I do agree for NA project a h22 would yield better results due the greater displacement.
but bang for your buck, boost is the cheapest way to get hp
ttamrekab
Aug 23, 2015 07:45 PM
MindBomber
Engine Swaps
Jun 28, 2015 08:40 AM
MindBomber
Engine Swaps
Mar 5, 2012 05:57 AM
TurboMan
Nov 7, 2007 12:58 PM
Hunter_racings
Feb 4, 2007 07:08 AM
