Cvjoints noise whiles turning wheel to sides
Old Jul 25, 2007
hardboiled's Avatar
hardboiled is an unknown quantity at this point
Got more questions beside Oil wich is solve already and thanks.
my Civic 4dr LX 2005, 26900miles... I notice noise coming from cvjoints when i turn the wheel all way to sides, is not constant all the time but is happening.
Want to know any tip i need to know of cvjoints problems from some experienced users, thanks alot
Old Jul 25, 2007
MisterFrankieJ's Avatar
MisterFrankieJ will become famous soon enoughMisterFrankieJ will become famous soon enough
Re: OIL maintRequire Light on, how do i turn it oFF
https://www.civicforums.com/forums/3...red-light.html
Old Aug 16, 2007
93 del sol man's Avatar
93 del sol man is an unknown quantity at this point
Re: Cvjoints noise whiles turning wheel to sides
It means one of the boots either inner or outer has split allowing they grease to leak out...... Over time dirt gets in and wears the CV joint what you are hearing is the worn out parts with little or no grease making contact..... In extreme cases the joint breaks completely and you are stuck, if the inner breaks sometimes it can damage the inside of the transmission.. Options are replacing the CV joint assembley which is easy, split boots and patchs are junk avoid them.
Jim-
Old Aug 18, 2007
HiPWR Racing's Avatar
HiPWR Racing will become famous soon enoughHiPWR Racing will become famous soon enough
dont replace the cv joint. its a waste of time and work. just buy 2 completely new half shafts for your axel.
to remove the half shaft you have to undo the bolt thats between your rims/hubcaps and the tire, undo the lower ball joint, smash out the brake rotor with a hammer so u dislodge the joint, then rip the half shaft out. its a really tight squeeze pulling it out so just break the seal of the boot completely. then put it in and put everything back together.
its a 2 man job, we actually used 3, but a lift is highly recommended
ImmortalEX
Detailing
78
Sep 4, 2015 05:35 PM
crowtoo
May 11, 2015 06:50 PM
civicns
May 8, 2015 09:49 PM
edgenet
May 2, 2015 08:00 PM
Dorval Andre
May 1, 2015 09:37 AM
