Knocking Clunking Sounds Over Bumps
Old Jun 3, 2007
s13_240sx_92's Avatar
s13_240sx_92 is an unknown quantity at this point
All,
I have a 01 Civic Ex Coupe. The car has been making a clunking, knock when going over bumps. The LCA bushings look OK and I was told by the old owner that they were replaced recently. I also just replaced the front struts and the noise is still there. Everything seems tight and I haven't a clue where the noise comming from.
The springs have the rubber covers on the bottom coils where they seat on the base of the strut.
I tightened all the upper bolts on the struts, still lots of noise. The car drives over bumps and sound like a total POS. I know Honda has gone down hill recently but this cant be right.
I've looked over the TSBs and searched here and Honda-tech but found nothing really.
Thanks all.
Old Jun 4, 2007
popee's Avatar
popee will become famous soon enough
Re: Knocking Clunking Sounds Over Bumps
i some what had the same problem it was my sway bar links and my shocks was leaking.
Old Jun 17, 2007
did you do the work to fix it? i was thinking taking out the endlinks and test driving it to see if the noise will go away.
I hate this POS car..
Old Jun 19, 2007
yamahaSHO's Avatar
yamahaSHO is an unknown quantity at this point
I've got a leaking strut up front and it's making noises over bumps. The steering wheel will shake when hitting bumps on the side the leaking strut is on. I'm going to replace all four struts with better units. It seems to be common for the stock struts to leak. What a shame. Mine started leaking at 24k miles.
Old Nov 12, 2007
pikuko's Avatar
pikuko is an unknown quantity at this point
Angry Re: Knocking Clunking Sounds Over Bumps
Hey Guys I got the same problem with my Honda Civic 2001. I had already replaced the following:
Struts 3 times Front and Back.
Springs
Sway Bar Links
Tires
Rotors
Bump Stops
and alot more than you can think.
Sep 26, 2023 06:44 PM
15EXCoupe
Jul 30, 2015 12:59 PM
viperGTS
Jul 27, 2015 08:40 PM
17
Jul 23, 2015 11:48 PM
mokkush
Jul 14, 2015 04:05 PM
