Knocking Clunking Sounds Over Bumps
Rep Power: 0 Knocking Clunking Sounds Over Bumps
All,
I have a 01 Civic Ex Coupe. The car has been making a clunking, knock when going over bumps. The LCA bushings look OK and I was told by the old owner that they were replaced recently. I also just replaced the front struts and the noise is still there. Everything seems tight and I haven't a clue where the noise comming from.
The springs have the rubber covers on the bottom coils where they seat on the base of the strut.
I tightened all the upper bolts on the struts, still lots of noise. The car drives over bumps and sound like a total POS. I know Honda has gone down hill recently but this cant be right.
I've looked over the TSBs and searched here and Honda-tech but found nothing really.
Thanks all.
Thanks all.
Rep Power: 0 Re: Knocking Clunking Sounds Over Bumps
did you do the work to fix it? i was thinking taking out the endlinks and test driving it to see if the noise will go away.
I hate this POS car..
I've got a leaking strut up front and it's making noises over bumps. The steering wheel will shake when hitting bumps on the side the leaking strut is on. I'm going to replace all four struts with better units. It seems to be common for the stock struts to leak. What a shame. Mine started leaking at 24k miles.
Hey Guys I got the same problem with my Honda Civic 2001. I had already replaced the following:
Struts 3 times Front and Back.
Springs
Sway Bar Links
Tires
Rotors
Bump Stops
and alot more than you can think.
Springs
Sway Bar Links
Tires
Rotors
Bump Stops
09-26-2023 06:44 PM
17
07-23-2015 11:48 PM
mokkush
07-14-2015 04:05 PM
