Voltage Regulator, where is?
Old May 23, 2007
eatingnachos's Avatar
eatingnachos is an unknown quantity at this point
I'm burning through ignition coils every four months or so. Someone suggested it could be the voltage regulator. Any idea where it is and how to check? Second guess is I might need a distributor. Plug wires, igniter and grounding strap are all relatively new.
90 civic hatchback
210,000 miles
-gets 45 miles per gallon!
Old May 23, 2007
cleanmagcivic's Avatar
cleanmagcivic should not be trustedcleanmagcivic should not be trustedcleanmagcivic should not be trustedcleanmagcivic should not be trustedcleanmagcivic should not be trustedcleanmagcivic should not be trustedcleanmagcivic should not be trusted
Re: Voltage Regulator, where is?
isn't it in the ecu
Old May 23, 2007
TRIZ's Avatar
https://www.civicforums.com/forums/3...-help-now.html
http://www.ecmtogo.com/removing_ecm.htm
Might help you^
Old May 23, 2007
regulator is somewhere part of the alternator. i think if that was bad, you would have bigger problems. and i think your car doesnt have ignition coils, just wires? i dont get it
Old May 23, 2007
Oh, it has coils all right. I've replaced three of them. It's right on top of the distributor when you remove the cap.
Old May 23, 2007
well idk, you could try a new alternator, but i dont think thats it. maybe something with the wiring.
Old May 23, 2007
Alpha 5's Avatar
If the coil is inside the distributor cap. Then you need to buy the cap that allows you to purchase a regular coil and mount it outside the cap. Then get a new ignition module. I think yours in going out. NOLOGY makes all the stuff you need to do this. Check them out.
Old May 23, 2007
skipbarber's Avatar
sounds like you have poor connections to the plugs. if the spark doesnt go to the plug, it tries to arc inside the coil because it's the closest path to ground. too much of this blows the coil over time. id check the cap/rotor/plug gap.
bolt-on-bandito
Electrical
32
Jan 15, 2020 03:25 PM
Hutch1051
Sep 29, 2015 09:20 AM
Bruce2
Sep 27, 2015 08:45 PM
RSKtakR
25
Sep 14, 2015 07:43 PM
Bricoleur
Sep 9, 2015 12:23 PM
