Engine Rattle/Vibration
Old Apr 6, 2007
thak's Avatar
thak is an unknown quantity at this point
Hi, I have a '01 4dr EX Automatic...and the car has a problem where over bumps and at about 55-60mph you hear this rattle. Sounds like its coming from the front drivers side, but cant really tell.
It happens at 55mph, put car in Neutral, sound still there. Sound does not change with teh RPMs. Rattle also happens at low speeds over bumps.
I was thinking front struts or engine mounts.
I see this TB # 010601 description talks about this issue, does anyone have a copy of it?
Thoughts?
Old Apr 6, 2007
DannyK35's Avatar
I'm bigger than you.
DannyK35 is a name known to allDannyK35 is a name known to allDannyK35 is a name known to allDannyK35 is a name known to allDannyK35 is a name known to allDannyK35 is a name known to allDannyK35 is a name known to allDannyK35 is a name known to all
Re: Engine Rattle/Vibration
check underneath and see if the heat shield is loose. This happened to me over the summer, there was this constant vibrating/rattling noise coming from the car and it sounded pretty ghetto.
Took it to my friend's shop, showed me the underbody and the mount for the piece had corroded through (Chicago winters = tons of salt on the roads). He just tore it off and the sound went away.
Old Apr 7, 2007
mugenman's Avatar
"mmmBAHHHH" - vtec y0
yeah i knew a guy with an 01 that did the same thin...and danny i LOLed at your sig
ImmortalEX
Detailing
78
Sep 4, 2015 05:35 PM
bluecoupe
Jan 23, 2002 05:50 PM
MyOtherRideIsBritney
Jan 20, 2002 03:16 PM
Cross
Jan 6, 2002 01:31 AM
supercivic01
South
Nov 30, 2001 11:27 AM
