Wheel studs???
Old Mar 20, 2007
TransformedBG's Avatar
I Hunt Goats, Rams, And Mustangs.
TransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of light
Wheel studs???
Anyone know if these will work for the 01 - 05 EMII?
http://store.summitracing.com/partde...5&autoview=sku
Old Mar 20, 2007
vacivic2005's Avatar
vacivic2005 is a jewel in the roughvacivic2005 is a jewel in the roughvacivic2005 is a jewel in the roughvacivic2005 is a jewel in the rough
Re: Wheel studs???
yea, those work on most honda's. i have them on my car
Old Mar 20, 2007
Re: Wheel studs???
and you have what car?
Old Mar 20, 2007
Zzyzx's Avatar
Autocross Junky
Re: Wheel studs???
Honda hasnt changed the spec's of their wheel studs since the beginning of time. If they fit on a Honda, theres a 99% chance they will fit on your honda.
Hell, My EM2 has the same wheel studs as an S2000....
Old Mar 20, 2007
Re: Wheel studs???
alright than.. thats what i was looking to hear!
Old Mar 20, 2007
Re: Wheel studs???
EM2
i'm sure you already know this, but you'll need to press the studs in, i think they charge something like $3-5/each stud at NTB. i did it myself, with a hammer, just have to make sure you keep everything flat so you don't warp/bend the hub.
Old Mar 20, 2007
HondaLuver's Avatar
Its a celebration bitches!
Re: Wheel studs???
nice, i need some, but i think imma get some extended studs with spacers
Old Mar 20, 2007
Re: Wheel studs???
i think some spacers that already have the studs to go with them also need to be pressed in...
i know the H&R 15mm ones you do. you can use your stock studs and bolt the spacer on.
if you want to do H&R 25mm i believe you're going to need to do extended studs.
Old Mar 20, 2007
Re: Wheel studs???
Damb you even did the Rear disk conversion.. im just wondering how it will work with drums.. im not cool like you! lol
Old Mar 20, 2007
electric130's Avatar
Re: Wheel studs???
what wheels are you wanting to run that you need extended studs and spacers?
Old Mar 20, 2007
RHCP0801's Avatar
Re: Wheel studs???
he is gonna run drag slicks
Old Mar 21, 2007
Re: Wheel studs???
what he said lol
only im running a 24.5x8.5x15 slick on a set of rota slipstreams 15x8 rims.
ill probably even end up rolling my fender some
Old Mar 21, 2007
Re: Wheel studs???
it'd probably work the same. i've never wanted to learn how to take apart those damn drums, so i went to discs when i was 4lug too.
if you're just doing this for slicks, you'll be fine with just having the fronts extended, i went extended because i plan on running dc5r wheels eventually. also when i did the conversion about 15 out of 20 of the studs were rusted/stripped to the point where i couldn't use them anymore.
Old Mar 22, 2007
Re: Wheel studs???
Aww i see.. well i know if my car ever has to run in the other classes i have to have wheel studs on all 4 wheels which is why im wondering how hard its going to be to do the rears now. But ill get her done.. Slicks came in yesterday soo woo weee!
Old Mar 22, 2007
Re: Wheel studs???
if you're ever thinking of doing a rear disc conversion, now would be the time to do it so you don't have to install extended studs twice.
Old Mar 22, 2007
Re: Wheel studs???
ehh to much work takes away from the sleeper value of my car lol.
Old Mar 22, 2007
Re: Wheel studs???
i can understand that .
nirvanaguy
25
Oct 26, 2017 07:26 PM
twd000
Oct 4, 2015 12:52 PM
siliconvalley
Sep 15, 2015 09:48 PM
junkyardguy
20
Sep 6, 2015 10:07 PM
mrwhos
Aug 11, 2015 02:03 AM
