Wheel studs???
I Hunt Goats, Rams, And Mustangs.
Wheel studs???
Anyone know if these will work for the 01 - 05 EMII?
http://store.summitracing.com/partde...5&autoview=sku
Autocross Junky
Re: Wheel studs???
Honda hasnt changed the spec's of their wheel studs since the beginning of time. If they fit on a Honda, theres a 99% chance they will fit on your honda.
Hell, My EM2 has the same wheel studs as an S2000....
Re: Wheel studs???
EM2
i'm sure you already know this, but you'll need to press the studs in, i think they charge something like $3-5/each stud at NTB. i did it myself, with a hammer, just have to make sure you keep everything flat so you don't warp/bend the hub.
Re: Wheel studs???
i think some spacers that already have the studs to go with them also need to be pressed in...
i know the H&R 15mm ones you do. you can use your stock studs and bolt the spacer on.
if you want to do H&R 25mm i believe you're going to need to do extended studs.
Re: Wheel studs???
what he said lol
only im running a 24.5x8.5x15 slick on a set of rota slipstreams 15x8 rims.
ill probably even end up rolling my fender some
Re: Wheel studs???
if you're just doing this for slicks, you'll be fine with just having the fronts extended, i went extended because i plan on running dc5r wheels eventually. also when i did the conversion about 15 out of 20 of the studs were rusted/stripped to the point where i couldn't use them anymore.
Re: Wheel studs???
Aww i see.. well i know if my car ever has to run in the other classes i have to have wheel studs on all 4 wheels which is why im wondering how hard its going to be to do the rears now. But ill get her done.. Slicks came in yesterday soo woo weee!
nirvanaguy
25
Oct 26, 2017 07:26 PM
junkyardguy
20
Sep 6, 2015 10:07 PM
