1st Gen 1972 - July 1979
2nd Gen 1979 - 1983
3rd Gen 1984 - 1987
4th Gen 1987 - 1991
5th Gen 1992 - 1995
Clock remains dim and resets to 1:00 every time the car is off...
Old Mar 15, 2007
ratedpeej's Avatar
ratedpeej is an unknown quantity at this point
...and in addition to that, when i try to install my car radio, it won't power on.
History:
My radio was stolen from my car the other night (yanked out by the wires ) and now I'm having all kinds of problems with that area of my car. I would say it was a blown fuse if not for the fact that all my fuses seem fine and my cigarette lighter still works. Any suggestions on what I can do would be greatly appreciated. In the meantime, I'm going to double check my fuses.
Thanks in advance for the help, and sorry if I posted this in the wrong spot0
Old Mar 15, 2007
serrilion's Avatar
serrilion has a little shameless behaviour in the past
Hey, all depends on what the theif damaged for wires... they could have striped 1 or another in the back and they could be causing a short, or there could be some cut 1's. I would say if you knew how bro, take off some panels of your dash and inspect the wirring.
Old Mar 15, 2007
CraigW's Avatar
Not sure of the year but, Most 12 volt outlet/lighters are switched these days.
I would check for a missing constant 12 volt source.
Old Apr 6, 2007
D16Z6_owner's Avatar
D16Z6_owner is an unknown quantity at this point
Re: Clock remains dim and resets to 1:00 every time the car is off...
Try checking the "back-up" fuse in the engine compartment
Old Apr 12, 2007
PowerWheels86's Avatar
PowerWheels86 is an unknown quantity at this point
depending on year i'd say some wires were damaged but like in my car when they stole my stereo the only wires they could have cut were the stereo wires... idiots didn't even take the harness like they were supposed to...
Old Apr 30, 2007
elusive_da's Avatar
elusive_da is an unknown quantity at this point
id pull the clock out and cheak wires, check all fuses under dash and in engine bay, and see if power antenna works....
gearbox
Electrical DIY
72
Nov 27, 2015 08:13 PM
civic_gt
Apr 19, 2015 08:15 AM
SSMatey
Apr 13, 2015 06:09 PM
Gunner
Engine DIY
Oct 6, 2012 12:37 PM
CivicHX01
Oct 22, 2001 11:11 AM
