1st Gen 1972 - July 1979
2nd Gen 1979 - 1983
3rd Gen 1984 - 1987
4th Gen 1987 - 1991
5th Gen 1992 - 1995
92 Civic Shaky Steering
Old Feb 26, 2007
Kowalske's Avatar
Kowalske is an unknown quantity at this point
A couple of days ago, my 92 Civic started to 'shake' while I am driving at low speeds. If I take my hands off the wheel, I can see it wobble left and right very slightly. This goes away when I increase speed and drives completely fine once I am at higher speeds (30+). Will an alignment take care of this? What could have caused it to happen suddenly?
Old Feb 27, 2007
zonk's Avatar
zonk is an unknown quantity at this point
hmmm have you hit anything recently...ie curbs, road debris, stuff like that. also when was the last time you had it aligned.
Old Feb 27, 2007
Kowalske's Avatar
I do not recall htting anything obvious. I have never taken this car in for an alignment...but this shaking started very suddenly.
Old Mar 2, 2007
PowerWheels86's Avatar
PowerWheels86 is an unknown quantity at this point
more than likely it's the alignment... but sometime hitting a good size rock in the road can put bumps in your tires and could be the reason for the shaking at low speeds you feel the bumps more etc. check the tires and if not go in for the alignment better safe than sorry...
Old Mar 3, 2007
zonk's Avatar
^^^ agreed, an align,ment should e done like every 6-12 months depending ont he road type you drive on, in centex where i am at the roads have a lot of bumps in them causing me to need an alignment like every 6-8 months , back in north carolina where i am originally from it is required maybe once every year. i know your car sitting a while would put bumps in your tires also, i am battling that problem since my car sat for a year while i was away at war. id have an alignement done and the tires balanced and rotated just to see if this solves the problem, and then write back if the problem doesnt go away
Old Mar 3, 2007
well i do an alignment every time i buy new tires... and that's about every 6 months... hahaha i need a new suspension... it's running my tires thin... '86 honda's are hard to find performance springs and shocks for...
Old Apr 30, 2007
elusive_da's Avatar
elusive_da is an unknown quantity at this point
Re: 92 Civic Shaky Steering
or check ur lug nuts.... good luck
Dorval Andre
General 7th Gen
34
Jun 3, 2024 08:11 PM
Xuhme
21
Aug 7, 2023 03:40 PM
moorebl
Aug 29, 2015 08:39 PM
bsmiley
Apr 27, 2015 01:27 PM
nymbus2k
Nov 11, 2001 08:53 PM
