1st Gen 1972 - July 1979
2nd Gen 1979 - 1983
3rd Gen 1984 - 1987
4th Gen 1987 - 1991
5th Gen 1992 - 1995
starter problems 1994 dx
Old Feb 24, 2007
pnoprodigy's Avatar
pnoprodigy is an unknown quantity at this point
Hi everybody, a couple weeks ago my car decided to stop working (1994 4dr civic dx, 5pd, 210,000 mi). Being a student, I have decided to undertake the task of fixing it myself. As far as I can tell, there is an issue with the starter or its electrical system. When I turn the key in the ignition, nothing happens.
When the problem first started, I'd turn the key once, nothing. Second time it would sound like the starter was charged half way. The third time the car would start. This got worse, until my car just wouldn't start.
I pulled the starter out of the car and had it hooked up to a testing machine at an auto zone and it seemed to work fine.
I tried to jump start the car, but that did nothing.
All my electronics work (radio, air, lights).
When I turn the ignition, the headlights stay on.
All the cables seem to be hooked up.
I have not been able to check the starter relay, because I'm not sure exactly where it is.
So, can anyone help my find exactly where the relay is? All I know is the left end of the dashboard.
Also, if anyone else has suggestions on what could be the problem, I'm all ears.
Thanks for any help!
Old Apr 30, 2007
elusive_da's Avatar
elusive_da is an unknown quantity at this point
Re: starter problems 1994 dx
the main relay is the grey box under the dash above the fuse box. its about the size of a stick of butter, its held up by a 12mm bolt.... good luck
Mich2019
Jun 7, 2015 11:23 PM
Allecr3
May 22, 2015 01:24 PM
usajags84
May 10, 2015 08:11 AM
oqjoi
May 9, 2015 10:31 PM
gabrown2
Apr 11, 2015 08:22 PM
