Break Lights Won't Turn Off.
Old Feb 15, 2007
Xecutioner's Avatar
Xecutioner is an unknown quantity at this point
I have a 94 civic hatchback cx and the break lights will not turn off. I pull the break pedal and it does nothing, the only way I can turn them off is to pull the 15 amp fuse under the hood. So if I don't pull the fuse my battery will go dead and I can't drive around with my break lights on all the time either. Please help.
Old Feb 15, 2007
skipbarber's Avatar
have you checked the pedal switch? have you ever modified your tail lights? do you happen to have a remote starter?
Old Feb 15, 2007
hwt101's Avatar
hwt101 is an unknown quantity at this point
that man is on the money check your pedal switch, i had tha happen w/my 89 civi HB, i felt so damn dumb.
Old Feb 15, 2007
bluehonda1's Avatar
bluehonda1 is an unknown quantity at this point
check your fuses.
Old Feb 15, 2007
Crashoveride's Avatar
Crashoveride is an unknown quantity at this point
I would also suggest checking to see if you have a bad ground or something. Did you by chance have your tail lights out any time recently?
Old Feb 15, 2007
Xecutioner's Avatar
They are the factory tail lights and I do not have a remote starter. I went out and checked the pedal switch. I pushed it in and messed with it and the lights are still on. How can I test to make sure that the pedal switch is the problem before I go buy one and install it and find out that it was not the problem? Thanks.
Old Feb 15, 2007
Could try unplugging the pedal switch and see if they go out, that should tell you if its bad or not.
Old Feb 15, 2007
Xecutioner's Avatar
Ok, I will try that thanks alot.
Old Feb 15, 2007
CraigW's Avatar
It's the switch.
Old Feb 15, 2007
aznstylez254's Avatar
Jspek Inspired
aznstylez254 is an unknown quantity at this point
more than likely its the brake light switch.
Old Feb 15, 2007
sql_civic's Avatar
I had a similar problem with my '84 Accord. I could not turn off the parking lights. Turned out that the circuitry inside the steering column overheated over time and a piece of solder fell off and shorted (actually completed) the parking light curcuit. I **** you not. For a while I installed a fuse tap and ran a second switch to the dash with an in-line fuse but then the lights stopped working altogether (the solder moved). When I opened up the steering column I saw what had happened and the dealer confirmed that it was common.
Anyways, just throwing that out there as a possibility.
Old Feb 16, 2007
Xecutioner's Avatar
It was the pedal switch. Thanks to all of you who helped me out on my problem. It's nice to know there is a web site that I can come to for help. Once again thanks everyone for all your help, you saved me some money rather than going to the dealership. You guys are great.
voblak2
20
May 4, 2023 02:08 PM
hernandexz
Oct 28, 2021 10:52 PM
cchance85
May 9, 2015 11:54 AM
shaejb15
Apr 26, 2015 07:44 PM
supYO
Nov 20, 2001 08:28 PM
