Seatbelt wont retract after accident
Old Jan 10, 2007
Da1lyDr1ver's Avatar
Thumbs up Seatbelt wont retract after accident
ok, my cousin ('01 civic EX) got into a little accident with his car over this past week.
after the accident, his front seatbelts will not retract into their places (both driver and passanger because he was driving and he had a passanger in the front). i guess its from the initial jolt of the accident and it somehow messed up the seatbelt retractor.
also, his SRS light is lit up on his dash too. he does not have side airbags either.
does anyone know if this is normal for the seatbelts to be like this? is there a simple fix or does he need to replace the whole seatbelt retracting unit?
thanks for any help.
Old Jan 10, 2007
beadebaserr's Avatar
beadebaserr will become famous soon enoughbeadebaserr will become famous soon enough
I'd probably just take it to the dealer if I were you, just because it's something that is probably putting your safety in jeapordy.
Old Jan 10, 2007
TransformedBG's Avatar
I Hunt Goats, Rams, And Mustangs.
TransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of light
Because the SRS has a miniature explosive in it and will disable the seat belts you, need to replace all your seat belts and fasteners.
Old Jan 10, 2007
Boilermaker1's Avatar
Jap-Euro Fusion
^^^^ I agree. the belts did their job, and you need to replace the restraints. and SRS isnt side airbags, its supplemental restraint system. that would be the airbags, the belt tensioners, etc.... that make sure you stay in the seat.
Old Jan 10, 2007
gsniper666's Avatar
gsniper666 has a spectacular aura aboutgsniper666 has a spectacular aura aboutgsniper666 has a spectacular aura about
take it to honda.. it happened on mine.. they have to reset the srs
Old Jan 10, 2007
mr.rowdy's Avatar
mr.rowdy is an unknown quantity at this point
yes take it to honda
Old Jan 10, 2007
TRIZ's Avatar
perfect time to rice it out and get some space shuttle harnesses!!
Old Jan 10, 2007
You calling me Rice? I need that to hold me in!
Old Jan 10, 2007
tucks15's Avatar
tucks15 is an unknown quantity at this point
the seat belts need to be replaced. there is a charge inside of each that makes then tighten up when you are in an accident. you could also try to get honda to cover it . i believe that they have a lifetime warranty on seatbelts
Old Jan 10, 2007
lxcivic2k1's Avatar
Damn, the whole restraint needs to be replaced after an accident? I would think just a reset. I hit someone at around 30mph and seatbelts did their job, but I ddin't have to do anything to them or have any srs light.
Old Jan 11, 2007
thanks for the input fellas.
and about the space shuttle racing harneses, yes, my cousin wasnts to get them now that he has to replace his seatbelts, tisk tisk. what a ricer, especially since he as stock seats
Old Jan 11, 2007
tucks15's Avatar
you can take it to honda and try to get them to reset it but i work in a honda autobody shop and ive seen lots that have to be replaced. good luck and i hope you dont have to replace them.
Old Jan 11, 2007
AmbulanceMonkee's Avatar
Pre-tensioners are miniature explosive charges that tighten the belt against you and keep you in the seat, as mentioned above. There's no resetting an explosive charge, it needs to be replaced.
Old Jan 11, 2007
redrocket600's Avatar
redrocket600 has a spectacular aura aboutredrocket600 has a spectacular aura aboutredrocket600 has a spectacular aura about
Note that you have to replace the seatbelt and the buckle (piece on the side of the seat, for only the belts that were buckled....
Old Jan 11, 2007
You need to replace:
and:
The seat belt its self.
Old Jan 11, 2007
wow, you guys have been more than helpful. thanks for the pictures.
i have a question. why does my cousin need to replace the belt buckle itself (pictured above)? is that where the "mini explosive charge" went off?
Old Jan 11, 2007
Thats were 1 of 2 went off. *that tube is one of the explosives* and the other is in the seat belt retractor its self. I dont have a picture to show you, but that was just one i had.
Old Jan 11, 2007
I was in the same boat as ur cousin, but i replaced ONLY the belt ONLY to discover that f-ing buckle also had to be replaced....
Like previously stated, it's just ONE of the TWO explosions per seatbelt....all in the name of "safety".
Wiggles
Sep 8, 2015 05:05 PM
Stock 99
Sep 5, 2015 06:06 AM
MamaBear2015
Aug 25, 2015 10:47 AM
jessica19699
Jul 29, 2015 05:51 AM
brainwashedmc
Jul 27, 2015 10:05 PM
