Suspension
Old Jan 24, 2006
vtec12's Avatar
vtec12 is an unknown quantity at this point
Suspension
Can anyone recommend some suspension upgrades?
What brands/types of suspension give best performance around corners for a FWD car?
Old Jan 31, 2006
twinkle's Avatar
twinkle can only hope to improve
I heard Koni had a pretty good upgrade kit for the suspension. What year civic do you have?
Old Jan 31, 2006
imported_TunerX's Avatar
imported_TunerX is an unknown quantity at this point
Skunk2 has a set of coil- overs on their website for a little less than $800. Depends on what your're going to do with car, if your going to road race get coil-overs, if your just driving around on the street get a good set of struts (KYB, Koni, Tanabe,etc) and get a set of lowering springs,sway bars and strut tower braces and urethane bushings. This is what i've been told, hope I helped.
Old Feb 1, 2006
twinkle's Avatar
That sounds like a pretty good deal. I was looking at a package the other day that was almost twice that at ~$1500.00 I can not find the link to it right now and my mind is not recalling the name of the kit.
Old Feb 1, 2006
Darth's Avatar
Darth is an unknown quantity at this point
Coilovers are still useful for road use, theres nothing wrong with using coilovers.
They are easier to fit, and easily adjustable. Having an all in one unit is alot better than going seperate struts and springs.
You'd notice a massive difference if you got coilovers.
Again, as someone mentioned, Koni are one of the leading brands in this field.
Old May 11, 2006
vtec12's Avatar
Thanks Darth
Does anyone else have input on this for me?
I know theres alot of new people now so just bumping my thread
Old May 11, 2006
05blkrs's Avatar
05blkrs is an unknown quantity at this point
i've noticed that drop springs are NOT AT ALL WORTH IT...... they are a cheap way to lower your car.. by the time you buy a good set of drop springs (we'l say $250) and a good set of adjustable rate struts (run about 150 each for tokicos) you're lookin' at $850 so why not go ahead and spend $900 or 1000 on a good set of fully adjustable coil overs? now keep in mind, there area always cheap ways to do things, but in the automotive industry, you get what you pay for... and as far as suggestions, ground control and tein make EXCELENT products
Old May 13, 2006
1997ek2k2's Avatar
1997ek2k2 is an unknown quantity at this point
Neuspeed also makes a pretty good set of coilovers for the honda civic and they utilize the koni threaded body struts as well. and they'll set you back around $850 US plus shipping and handling...not to mention they also have a complete set of front and rear upper and lower sway/tie/strut bars, that would really help you with body lean. I have a 97 EK and without them on there the car has some nasty bad body roll...got the order put in for the coilovers and bars and a good roll cage from autopower should be coming in soon.
Old May 14, 2006
CG99's Avatar
CG99 is an unknown quantity at this point
Neuspeed? Never heard of them.
If they use Koni equipment wouldnt you be better off going straight through Koni?
Old May 15, 2006
fivespeed's Avatar
fivespeed is an unknown quantity at this point
I would use the same rules for road driving as for street racing BECAUSE they can be one and the same at the drop of a hat. Yes there is a small price differential between drop struts and coil overs.
I suggest driving somebody else's ride with these modifications and seeing what the feel of the car is like. Better know before you install......
Tedverseti
Apr 23, 2020 01:45 PM
Mad Dog Tannen
Oct 19, 2016 08:12 PM
Tedverseti
Sep 29, 2015 05:41 PM
czarlun
Sep 14, 2015 08:16 PM
Mad Dog Tannen
Sep 12, 2015 12:48 AM
