Hood Won't Open
Old Dec 4, 2006
ES2Slow4Me's Avatar
ES2Slow4Me is an unknown quantity at this point
Hood Won't Open
I start my car this morning, it started fine. I go to leave, clutch in, put it in first, and....loose gas pedal. Yesterday I was messing with the throttle cable to tighten it. I get distracted and close the hood. No problem, It's progagly just too loose or it disconnected. So i pop the hood to take a look and i hear a "BING", and nothing. I'm assuming that the spring in the latch broke. It's fixable, i'm sure, but not a huge deal, as it's going in for a lot of work soon, i'll just throw it on the bill to fix.
But I can't leave my house, because I can't get the hood open to fix the throttle cable. Any ideas as to how to get it open? Just long enough to fix the problem. The hood is loose, but because of the grille, i can't get a screwdriver in there to release the latch. My guess is that it's the top spring, because there is some give, but it's still stuck in there. I don't care about fixing the hood at the moment, I just want to know how I can get up in there to fix the cable. I can't cleanly remove the bumper, because the pegs are out of reach for the grille.
Do I have to force it? (Pry the grille from the bottom, away from the bumper? I would have a hole, but it's replaceable. If I get that loose, I'm still stuck witht he top connected under the hood. I don't want to tear anything apart. I need help ASAP. I've got a few minutes of light left, then i'm stuck using a flashlight until I get it. I dont' have a choice to but to get my car running before the morning. Any help is appriciated.
Old Dec 4, 2006
againifall's Avatar
Go Team Venture!
againifall is a glorious beacon of lightagainifall is a glorious beacon of lightagainifall is a glorious beacon of lightagainifall is a glorious beacon of lightagainifall is a glorious beacon of light
no you can not pry the grille off.. theres srsly like 328057208357 screws holding that thing in place...
if you have long skinny arms you can try jackin up the car and reaching it from the bottom... i think you are going to need a screwdriver...
http://img.photobucket.com/albums/v2...r/PA220027.jpg
it moves towards the drivers side..
if you dont have your radiator cover in place this can be done fairly easly... but... my guess is yer going to end up with a bloody knuckle and a long list of new swear words...
Old Dec 5, 2006
ES2Slow4Me's Avatar
wow, i really am screwed, aren't I. There is no possible way to open the hood if the latch breaks?
Old Dec 5, 2006
PunkingCivic's Avatar
I need TP for my bunghole
Bend a wire coat hanger
use the hook end and slide it in between the hood and grille or light
start fishing around like your using a slim jim to open the door.
Old Dec 5, 2006
ES2Slow4Me's Avatar
I'll give that a shot. I just woke up. I'm making a good breakfast before i get nice and pissed off at the car. Other suggestions appriciated.
Old Dec 5, 2006
ES2Slow4Me's Avatar
got it. thanks.
usajags84
15
Aug 19, 2015 03:12 AM
Billybob1963
May 31, 2015 07:37 PM
MamaBear2015
May 18, 2015 07:37 PM
Gunner
Engine DIY
Oct 6, 2012 12:37 PM
ALLMAN
Engine DIY
73
Jan 19, 2009 11:21 PM
