Steering shakes when breaking!!
Old Nov 16, 2006
korhk's Avatar
korhk is an unknown quantity at this point
Exclamation Steering shakes when breaking!!
Hey guys
I'm having a problem where my steering shakes volently when i'm breaking while going at highway speed. It won't do it when i'm doing 45 or less, but when i'm up at 65~75 and start to break, the thing shakes/vibrates like crazy.
just asked the guys at local shop, and they said it might be warped rotars.. but why would it get warped without any reason???
anyone had this problem and had it fixed??
help me out~ thx
Old Nov 16, 2006
korhk's Avatar
By the way, i tried to search, but it seems like there was a similar case before, but no one really answered the question..
Old Nov 16, 2006
againifall's Avatar
Go Team Venture!
againifall is a glorious beacon of lightagainifall is a glorious beacon of lightagainifall is a glorious beacon of lightagainifall is a glorious beacon of lightagainifall is a glorious beacon of light
sounds like problem is warped rotors... its an easy innocent thing to screw up.. you dont have to do anything "stupid" to warp them... simply driving through town in traffic using yer breaks and then hitting a big puddle is the easyed way to warp them... its how i have managed to warp every set of rotors on ever car i have ever owned... its not a big deal.. mostly just annoying...
http://www.trustmymechanic.com/brakewarp.html
google will give you even more answers
Old Nov 18, 2006
puidokas's Avatar
puidokas is an unknown quantity at this point
Just get them turned, Brought mine to NAPA and got them back the next day. Only cost like $20
Old Nov 18, 2006
zachpolo's Avatar
zachpolo is an unknown quantity at this point
I had the EXACT problem.. I got an alignment all a FULL set of tires and It runs like new.. Check your tires for worn patches or "bubbles". Hope this helps.
Old Nov 20, 2006
greeen01civic4d's Avatar
its your brakes, especially if it only happens when braking. i work with tires all day long, and see slipped belts constantly, and they cause shaking at all speeds, braking or not.
Old Nov 20, 2006
BATANG KANTO's Avatar
BATANG KANTO has a little shameless behaviour in the past
you need a tire balancing.
Old Nov 20, 2006
not so much, balance has nothing to do with it.... get new rotors
Old Nov 30, 2006
zillaz's Avatar
zillaz is an unknown quantity at this point
I know that in my 04 5speed it vibrates a little bit when one tire is a little soft.. but it sounds like it's alot worse in your case. Check the pressure in all of your tires.
Old Dec 1, 2006
Suzy Q's Avatar
2 cups sweety 8 cups bitch
Suzy Q has a reputation beyond reputeSuzy Q has a reputation beyond reputeSuzy Q has a reputation beyond reputeSuzy Q has a reputation beyond reputeSuzy Q has a reputation beyond reputeSuzy Q has a reputation beyond reputeSuzy Q has a reputation beyond reputeSuzy Q has a reputation beyond reputeSuzy Q has a reputation beyond reputeSuzy Q has a reputation beyond reputeSuzy Q has a reputation beyond repute
1) get your tires balanced
or 2) get your brakes checked
Old Dec 1, 2006
it really does sound like warped rotors.. just my opinion..
Old Dec 1, 2006
charcoalex's Avatar
charcoalex is an unknown quantity at this point
i just had that problem. check your rotors. feel carefully on the back and see if they are splintered. i just fixed mine today. rotors were 20 bucks a piece and i just bought 50 buck cereamics.
Old Dec 7, 2006
korhk's Avatar
thx everyone for quick replies. Just for later use "if anyone has same problem and is searching for an answer", This problem was due to the warped rotors.
I've just went into local shop, and they turned my rotors (around $20), and my car runs just fine now.
Old Dec 8, 2006
EX4Dr's Avatar
EX4Dr is an unknown quantity at this point
Honda rotors are notorious for warping. Turning the rotor will only buy you a bit of time. It'll mostly likely get warp again in the near future. When it make sense economically, replace it with decent aftemarket ones, then do a proper break-in and perform properly seasoning of the new rotors. This will reduce the chance of warping dramatically.
pizzahutcombo
Suspension
Jul 13, 2021 09:41 PM
muniorbust
33
Aug 31, 2015 08:59 PM
amrhamed
Aug 7, 2015 11:39 AM
qlitten
Jul 21, 2015 03:12 PM
Causemo
Jul 4, 2015 07:11 AM
