new mods
Old Nov 7, 2006
jrock's Avatar
jrock will become famous soon enoughjrock will become famous soon enough
new mods
Just got my 02 civic coupe ex tinted...35 percent on the front windows and 25 in the back...ill post pics soon. Also ordered from street levelperformance.com an exedy organic stage 1 clutch as well as the act streelite flywheel.........what type of change in performance can I expect from these upgrades on my trans, minimal to none?
Old Nov 7, 2006
rutscivic's Avatar
rutscivic is an unknown quantity at this point
did you need a new clutch?
Old Nov 7, 2006
PunkingCivic's Avatar
I need TP for my bunghole
Congrats
Driveability is similar to the stock clutch. Pedal efforts will be slightly higher because of the higher clamp loads. Also, all their clutch discs have spring center dampers to reduce drivetrain shock. The ACT flywheel will help provide significantly improved engine response, acceleration
Old Nov 7, 2006
jrock's Avatar
yes....I do need a new clutch.....and I having the bearings replaced as well..I was having an awful sound......so while it is open I am replacing everyting
Old Nov 8, 2006
familycar's Avatar
as far as daily drivability i think the stock flywheel is better. with the act you have to launch and start out at a higher rpm and you also need to keep the rpms up high when shifting or you will bog down. flywheels are great but better for higher hp cars. the pedal feel isnt much different than stock. a little stiffer but still nice.
Old Nov 8, 2006
rutscivic's Avatar
yea i woulda kept the stock flywheel, the ACT clutch is s good buy...
Old Nov 8, 2006
fidencio74's Avatar
fidencio74 is an unknown quantity at this point
I got a ACT streetlite and organis ACT clutch and I don't like the way my car drives now, Your front end is going to shake if you don't rev enough. I like the stock flywheel better. Don't expect too much.
Old Nov 8, 2006
sl33pyriceboi's Avatar
not to high jack, but u guys would recomend the stock flywheel with an ATC clutch? (for daily driving on NA cars)
Old Nov 8, 2006
familycar's Avatar
the clamping power of the clutch you get should depend on the power level you want to achieve. if your only going to do basic bolt ons then stick to a stg 1 act or exedy organic. drivability isnt much different than stock but can support about 50% more power
UltraHDGames
Jun 8, 2016 05:16 PM
ricer_em2
May 11, 2016 08:09 PM
kmarcet
Sep 26, 2015 10:25 PM
ZoSoIV
Sep 17, 2015 07:17 PM
muniorbust
33
Aug 31, 2015 08:59 PM
