steering wheel shaking alot..whats wrong
Old Oct 18, 2006
MotorWeb EM2's Avatar
MotorWeb EM2 is an unknown quantity at this point
i just got new 17" flaken rims and new toyo proxes 4 put on my car, before i had just normal 15 inch wheels and tires. i know they say the ride is more bumpy and you can feel the road more, but when im driving like 50 and above, my steering wheel shakes pretty roughly. like side to side. not the entire column, but just the wheel. like it turns left then right then left then right, really quickly. i can get used to it but its just really annoying on the freeway having my hand shake with the wheel. anyone know what might be wrong.
Old Oct 18, 2006
lumina5201's Avatar
lumina5201 is an unknown quantity at this point
last time i had a my steering wheel shake was because of a bad tire. i had this really bad flapping noise and a lot of rumble from the steering wheel when going 50+. a few days later it blew out on me on the highway. maybe your tires didnt get mounted correctly? or mayb it had a defect like mine, too bad mine wasnt covered by a warranty though.
Old Oct 18, 2006
boosted.es2's Avatar
boosted.es2 is a jewel in the roughboosted.es2 is a jewel in the roughboosted.es2 is a jewel in the rough
your new set of wheels need to get balanced
Old Oct 18, 2006
phuviano's Avatar
Slowest 7thgen in the GTA
The car pulling left to right, and vice versa is normal when going to a bigger tire size on a wider rim. You get used to it.
Old Oct 18, 2006
i got them balanced and everything. and its not the car that doing it, its just the steering wheel, the car drives fine.
Old Oct 19, 2006
streetglower's Avatar
based on experience and working with tires at work. balancing may be the issue, but were I work, we can do a road force on the tire. even with brand new tires I have installed, I have run into a few that had too much runout or it was just a bad tire. and the tire will still balance out. I would take it back and have them rebalance them and see if they have a way to check the tires.
Old Oct 19, 2006
TeamSF_em2's Avatar
Show and Go. N/A is BEST.
TeamSF_em2 will become famous soon enoughTeamSF_em2 will become famous soon enough
possibly allignment factors as well. for example... if your going on a straight 4 lane freeway and your car merges 2 lanes or more in less than 7 seconds while your hands are off the steering wheel your allignment requires adjusting.
or you havent torqued your wheels tight enough. get a torque wrench set it at 80 lbs. and double torque all your lug nutts. i had steering wheel vibration before after i rotated my tires one time, just re-torqued all my lugnuts and the problem vanished.
conspiracy90
Jun 7, 2023 01:01 PM
bravo79
Suspension
18
Feb 10, 2022 09:52 PM
honda200192
Suspension
Oct 27, 2019 12:23 PM
Optimus34
May 25, 2015 11:52 PM
RickyRocket
Nov 30, 2001 10:14 AM
