exhaust manifold
Old Oct 18, 2006
HondaScott's Avatar
HondaScott is an unknown quantity at this point
Exclamation exhaust manifold
Hello,
I have an 02 Honda Civic DX which has problems with the exhaust manifold. It has a small crack and a lot of green corrision around it. I am not sure if I should get it fixed, which would cost over $600+ or I can get it taken off and welded together and it would cost around $200. Please let me know if it will become a problem?
Thanks,
Scott
Old Oct 18, 2006
Syke Fu's Avatar
Syke Fu will become famous soon enough
Yep thats a problem. You will eventually get a CEL because that crack is allowing extra air into the system and the O2 sensor(s) will see it. You car will either start to lean out or run rich because of it.
Old Oct 18, 2006
HondaScott's Avatar
What does start to lean out or run rich mean,lol. not a big techie
Old Oct 19, 2006
bobsagator's Avatar
bobsagator is a glorious beacon of lightbobsagator is a glorious beacon of lightbobsagator is a glorious beacon of lightbobsagator is a glorious beacon of lightbobsagator is a glorious beacon of light
An exhaust leak will confuse your O2 sensors causing the ECU to dump more fuel (run rich) or less fuel (run lean) to compensate. Either way, not good.
Replacing the exhaust manifold (header) is pretty easy to do by yourself. You can get a new one with gaskets and have a good weekend project. It's just 7 bolts (5 top and 2 bottom) and a couple of sensors. Be sure to have deep sockets with an extension and some liquid wrench or penetrating lubricant. Here is a DIY that is beyond what you will do but there are lots of pics. Check around the For Sale section to see if anyone is selling their used header (note EX header is different and can't be used unless you want to replace the downpipe, cat, cat back, and extend some sensors too).
nola000
Engine start problems
63
Feb 17, 2023 09:18 PM
jdh022764
18
Nov 3, 2015 06:44 AM
TheRiddicles
Sep 21, 2015 03:34 PM
Mannimarco
Sep 7, 2015 10:01 PM
dantheman42
Sep 4, 2015 01:10 PM
