dash light change
dash light change
When I turn my lights on the right side where the gas gauge is is not illuminated very bright. I am thinking the bulb is burned out. Anyone out there know is it hard to replace it or can it be replaced at all. OR is this the way it is. It is a 2002 EX coupe. thanks.
I did the blue LED conversion. its awesome, if you guys want to see let me know and ill post pics. Id go for that instead of just replacing the bulb.
Is it alot of work. How much work is it to get the dash cluster out ?? Gearbox said couple of screws then pull like hell and the trim comes off then get the cluster out. I would convert if not too time consuming. (I got 9 month twins and a 5 yr old so time is precious!!) thanks.
you gotta know what youre doing and even then it takes a few days. you may break stuff and get mad lol. if you know nothing about leds and soldering and epoxy and drilling, maybe best not to do it.
sometime they the sheet stuck out n prevented my needles from moving.......
how r they for the civics?
eh, they fit okay if you tape them good, but the inverters usually have problems or they flicker or who knows what else. nothing but trouble. EL is a very picky technology and if you go cheap they wont last long.
voblak2
20
May 4, 2023 02:08 PM
twtron
Apr 17, 2015 12:09 AM
dooner24
Apr 14, 2015 07:51 PM
SSMatey
Apr 13, 2015 06:09 PM
