dash light change
Old Oct 17, 2006
ccarbo's Avatar
ccarbo is an unknown quantity at this point
dash light change
When I turn my lights on the right side where the gas gauge is is not illuminated very bright. I am thinking the bulb is burned out. Anyone out there know is it hard to replace it or can it be replaced at all. OR is this the way it is. It is a 2002 EX coupe. thanks.
Old Oct 17, 2006
sl33pyriceboi's Avatar
they are bulb #74 i believe...there is a blue LED DIY conversion on here.... search for it and it'll show u how to take ur dash off the 01/02
Old Oct 17, 2006
ccarbo's Avatar
thanks! I did some searching but couldn't find it. I will try again.
Old Oct 17, 2006
jester444's Avatar
Dain Bramaged.
jester444 is an unknown quantity at this point
There's a lot of conversation going on about LED conversions... Talk to Gearbox. As with almost any DIY, he knows the most of anyone on here.
Old Oct 17, 2006
ccarbo's Avatar
I will talk to him. I just want to replace it, I am not going to convert it. Looks cool, though.
Old Oct 20, 2006
southOCem2's Avatar
southOCem2 is an unknown quantity at this point
I did the blue LED conversion. its awesome, if you guys want to see let me know and ill post pics. Id go for that instead of just replacing the bulb.
Old Oct 20, 2006
ccarbo's Avatar
Is it alot of work. How much work is it to get the dash cluster out ?? Gearbox said couple of screws then pull like hell and the trim comes off then get the cluster out. I would convert if not too time consuming. (I got 9 month twins and a 5 yr old so time is precious!!) thanks.
Old Oct 20, 2006
you gotta know what youre doing and even then it takes a few days. you may break stuff and get mad lol. if you know nothing about leds and soldering and epoxy and drilling, maybe best not to do it.
Old Oct 21, 2006
ccarbo's Avatar
Yeh that is too long for me patience level. I got what it takes in the soldering, drilling, epoxy department. It just don't trip my trigger... thanks for all the help!! :-)
Old Oct 21, 2006
CraigW's Avatar
Get the original bulbs from Honda if you plan to repair the cluster. It is my understanding #74 bulbs may not work.
Old Oct 21, 2006
lxcivic2k1's Avatar
You can always find some indiglo and just use those, since they don't use the factory lighting.
Old Oct 21, 2006
i had em for my acccord........and had nothing but trouble with them...
sometime they the sheet stuck out n prevented my needles from moving.......
how r they for the civics?
Old Oct 21, 2006
eh, they fit okay if you tape them good, but the inverters usually have problems or they flicker or who knows what else. nothing but trouble. EL is a very picky technology and if you go cheap they wont last long.
Old Oct 23, 2006
jester444's Avatar
Dain Bramaged.
Sad thing is, that's the kind of thing people usually go cheap on, so they gain a terrible reputation.
voblak2
20
May 4, 2023 02:08 PM
gearbox
Electrical DIY
72
Nov 27, 2015 08:13 PM
twtron
Apr 17, 2015 12:09 AM
dooner24
Apr 14, 2015 07:51 PM
SSMatey
Apr 13, 2015 06:09 PM
