bang bang turning left with new strut and spring HELP!!!
Old Jul 29, 2006
cwo715's Avatar
Falken Master
cwo715 is just really nicecwo715 is just really nicecwo715 is just really nicecwo715 is just really nice
hey guys i just dropped the vic on progress lowering springs and tokico blues all around. problem though. on the right strut/spring whenever i turn that wheel to the left all the way it goes clunk bang.. my friend and i cannot figure out what it is.. the ride is fine and it doesnt do it unless i bang a 'K' turn.. anyone know what it might be?
Old Jul 29, 2006
GhostAssassian's Avatar
GhostAssassian is an unknown quantity at this point
before they lock this id look up in the stickies
Old Jul 30, 2006
cwo715's Avatar
Falken Master
ok well i did what the sticky said. we even checked the bearings to make sure they were ok.. fixed the right side so that doesnt make a noise anymore.. the left side however still makes a clunking sound when steering all the way to the left. its lined up with the arrows on top even. I have the progress springs w tokico blues
Old Jul 30, 2006
30seconds's Avatar
30seconds is a glorious beacon of light30seconds is a glorious beacon of light30seconds is a glorious beacon of light30seconds is a glorious beacon of light30seconds is a glorious beacon of light30seconds is a glorious beacon of light
are there any other markings on the stock struts and top mounts, like white lines or whatever? mine had the arrows and lines on it, you have to line it up perfectly from the the stock to the tokico
Old Jul 30, 2006
cwo715's Avatar
Falken Master
yea i had yellow lines like someone took a marker and a ruler and went from one side to the other.
Old Jul 30, 2006
30seconds's Avatar
try lining those up and see
Old Jul 30, 2006
robbclark1's Avatar
Retired suspension supermod.
If you put them on tokico's there is no need to index. Make sure that the springs are seated correctly and bearings are lubed.
Old Jul 30, 2006
cwo715's Avatar
Falken Master
lubed the hell outta the Right one.. but got dark before pulling the left one.. also on the springs there were rubber pieces that wrapped around the spring itself. we put this on the 2nd coil from the bottom on the right one and it stopped making the noise.. gonna lube the left one and put the rubber thing on the coil.. looks like the powder coating got rubbed .
Old Jul 31, 2006
robbclark1's Avatar
That should solve the problem. If not, let us know.
Old Jul 31, 2006
deanob's Avatar
deanob is an unknown quantity at this point
Is it possible the ball joint isn't securely in place? I know its easy to assemble the strut and spring without it seating properly.
Old Aug 9, 2006
lewal's Avatar
lewal has a spectacular aura aboutlewal has a spectacular aura aboutlewal has a spectacular aura about
any update?
Old Aug 15, 2006
phuviano's Avatar
Slowest 7thgen in the GTA
My suspension did the same thing until I fixed it...lol.
Well, this is what fixed my problem. I had the exact same problem. When turned fully to the right or left, bang bang sound. Sounded like a broken ball joint.
Anyways this is what I did. I re-torqued the two 16mm (14mm for 01-03 vics) bolts that are at the bottom of the struts. Both sides where tighten too much. I put 116 lbs/ft torque (that's what the FAQ here says), and they don't make that banging sound any more.
Try that see how that works out.
Nalmonte
Suspension
Jun 9, 2015 07:08 PM
tomg
May 21, 2015 07:05 AM
Dorval Andre
May 1, 2015 09:37 AM
GH04si
Apr 15, 2015 08:13 PM
Russps
Nov 8, 2001 02:00 AM
