oil pan drain bolt won't budge!!
I've decided to change the oil in my car myself from now on so I attempted to do it today but the drain bolt wont budge at all. I used to go to valvoline and have it done. do you think they overtorqued it so it's not budging?
and also, i did not see the oil filter at all... where is that located?
maybe i'm just better off getting someone else to do it?
Official Rattlesnake Hunter
You havent stripped it yet???
Have you??
You need leverage over the bolt.
I have some troubles with that bolt also.
A rubber hammer is my best friend!
Have you??
i hope i didnt strip it. i was using an adjustable wrench because I didn't have a big enough attachment for my ratchet. do you know what size that bolt is so I can buy an attachment for my ratchet?
DAMN bro I hope you’re not using a cresset wrench for this...
JUST get a 17mm wrench & a hammer!
Other wise if you already striped it
take it to the dealer & have them drill it out!
Good luck man!
Good luck man!
Ever Wonder What P.O.S.B.A.S. Is An Acronym For
you won't have to take it do the dealer if you have a dremel! you can dremel it down to fit a socket. if you do that, please make sure you have a new oil plug to replace the old one, lol!
Chances are the idiots at valvoline used an air gun to put the drain bolt in. And why can't you use a crescent wrench? It may not be the best tool, but it will work. Personally, i use a 6pt box wrench, less chance of it slipping off the bolt and rounding off a corner. And if you cant get it off by trying to turn, just put a open ended wrench, or socket wrench on the plug, and bang it one way with a hammer. If my memory serves me right, you should be pushing the wrench towards the passenger wheel, counter-clockwise.
I forgot to mention if your drain plug is in that tight, your crush washer is probably toast. The crush washer goes between the drain plug, and the drain pan to prevent the pan threads from stretching in the event that the plug gets tightened too much.
also, if and when you get this resolved, you should buy a fumoto oil drain valve. www.fumotovalve.com.
many people here use it, and it work well. it's really well built and it's nice just draining it just by opening that valve.
pm me if you want one.
thanks for the advice guys. i will retry it tomorrow and see how it goes with a 17mm wrench. i think the adjustable wrench i'm using adjusts itself bigger when I try turning it hard.
I had this same problem the first time I changed my oil by myself, you just need a really long wrench with some leverage to get it off. Since you're under the car, gettin a good angle will be tough, just make sure you don't round off the bolt. Getting the oil filter off and back on can be a PITA, but just breathe, relax and you'll get it done.
I managed to get to home depot 5 min before they closed to pick up a bigger ratchet and 17mm socket. I think i actually loosened the bolt when i was under there the first time because it took no effort at all to remove it with the 17mm socket, and there was a small puddle of oil on my driveway. thank god the oil didnt drain out while i was driving lol. i'm glad i know how to do oil changes myself now
thanks for all your help guys!!
one more question tho... the 2 metal loop things under the front of the car is where you put the jack stands right? that's where i put it but it didnt seem too stable.
thanks for all your help guys!!one more question tho... the 2 metal loop things under the front of the car is where you put the jack stands right? that's where i put it but it didnt seem too stable.
I think those are the towing points you are talking about, and no that wouldn't be very stable. Personal I would just buy a set of ramps, I think I picked mine up from Autozone for $15, and it makes life much easier, no more jacking cars up.
Re: oil pan drain bolt won't budge!!
How do you get the filter off? Will those universal filter band wrenches work or do you need those cap type ones that fit on the end of a socket wrench? Can you remove it by hand? Is there enough room up there without getting burned?
Pwning Noobs 24/7
The best way to get an oil filter off is to use these bad boys, this is the best tool IMO, cause it clams and all you got to do is twist
When i first tried to do an oil changed i used one of these
and they suck, didn't grip for its life.
Also when you put a new oil filter one, it only needs to be hand tight, doesn't need to be real right, the oil pressure will make a seal.
oil filters are only supposed to be hand tightened so with a little muscle they can be taken off. and since im the only one who changes my oil, its not liek im struggling cuz the guy before me was all vin desiel like (or however u spell his name). alot of people do you those clampy things that ^ guy said. I gues if its too hard, go invest in one. but siince ur gona be doing it from now on..why bother? remmeber HAND TIGHTENED.
try not to jack up at the "LOOP THINGS" just behind the front bumper. those are tow points for tow trucks to winch (pull) your car onto their bed.
the proper place to put JACK STANDS (DO NOT USE MULTIPLE LIFTING JACKS) is on the reinforced rail behind the front wheels and rear wheel wells. see picture or linked thread
https://www.civicforums.com/forums/p...398-post7.html
ps. congrats on your first DIY oil change
Pwning Noobs 24/7
there is also jackpoints in the front and back, if you look under the front bumper there is an arrow point to a jackpoint, where its reinforced steel, and on the back, you can jack it on the lil loop
I just burnt my tongue
no ratchet get a 17 mm wrench and a rag...put the rag on the wrench and hold it with you're left hand than strike the back of your hand with your other hand and it should come loose...trust me i do it all the time and i do oil changes all the time...actually 5 days a week cuz its part of my job lol
Vaguexo
Jun 13, 2015 04:11 AM
jmdcivic
May 20, 2015 09:52 PM
Unleaded
Jun 26, 2007 09:25 PM
