Help wid homemade turbo!!
Old Jul 21, 2006
asadrana83's Avatar
asadrana83 will become famous soon enoughasadrana83 will become famous soon enough
Guyz im planning to boost my D17 wid stock internalz...i need sum advice wid my plan cuz i dun wanna get stuck up in da middle ov da project...so lil help required ...i`ve got IHI-RHF5 BB turbo, intercooler, greddy BOV, manifold, VAFC II, performance clutch, oil lines etc...now herez wht im planning to do for the fueling thngie. im gona install walbro in-tank fuel pump...get bigger injectors (probably RSX 440cc) and fine tune them wid VAFC II...i plan to install a thicker head gasket just to decrease the compression a lil and run arnd 8~9 psi ov boost...im lil confused wid da fueling part...is this going to work?? plus is there anythng else required for going turbo??
Old Jul 21, 2006
2k2whitecivic's Avatar
2k2whitecivic is an unknown quantity at this point
you cant tune rsx injector with vfac
Old Jul 21, 2006
Rennen's Avatar
New Mod on the Block
the proper use of the english language is probably required when installing a turbo
Old Jul 21, 2006
CenZ's Avatar
PWIT
tru
Old Jul 21, 2006
flipmoderacer02's Avatar
Old Jul 21, 2006
thefever's Avatar
I need a drop
thefever is a jewel in the roughthefever is a jewel in the roughthefever is a jewel in the rough
is this a joke?
Old Jul 21, 2006
armieo's Avatar
< My future wife.
ey cuz I wud tell you wut to do but lyke i don have enough time ryte now an i don know shiet bout turboz but ya bro mebbe i holla at chu later yaheard?
holla back.
one.
Old Jul 21, 2006
Havok2k1's Avatar
Wicked Pissah Admin
x3...
Old Jul 21, 2006
ctx66's Avatar
ctx66 will become famous soon enoughctx66 will become famous soon enough
He could, but i think it'd be better to go a little bigger than those since you wouldn't be pushing them as close to their max duty cycle
Old Jul 21, 2006
RHCP0801's Avatar
how do people talk like that?
Old Jul 21, 2006
01HonderCivic's Avatar
Don't be a n00b, search ftw
With a maximum of 10 good brain cells
Old Jul 21, 2006
XSRCivic's Avatar
XSRCivic is just really niceXSRCivic is just really niceXSRCivic is just really niceXSRCivic is just really niceXSRCivic is just really nice
jeez take it down a notch people. For turbo I wouldnt suggest anything except Emanage and bigger injectors AT LEAST. The VAFC cant adjust ignition timing and can only adjust fuel for 12 points across the rpm band. The emanage is FAR more superior in tunability. If you really wanna get serious with it, a standalone (AEM EMS) is the true way to go. Stock RSX injectors come in 240cc and 310cc. Most people use the RSX injectors with a mild boost setup.. They do tend to run full duty cycle once you hit the 210+ hp range. A bigger pump is a good thought, the stock one tends to burn up under heavy use.
You need fuel upgrades when going turbo, the stock system wont cut it for long. The motor will be fine if you have it tuned by a professional that is proficient with what engine managment you are using, hopefully its emanage or AEM.
Old Jul 21, 2006
Civicman1988's Avatar
get 750 injectors
Old Jul 21, 2006
tuner04civic's Avatar
spell check pwns you
sorry had to use that.
if you dont know what your doing and need help on parts i would buy a kit such as dezod and add on the parts. otherwise theres a few threads about boosting custom i would try search.
good info +1
Old Jul 22, 2006
asadrana83's Avatar
Thanks for the info...That expalins much...But dont you think that i can run 8~9 psi of boost on stock internals without retarding the ignition timing? Plus is there any change that the ECU retards the timing (to an extent obviously) if it detects any knock?
Old Jul 22, 2006
XSRCivic's Avatar
In the past people have run 8-9+ psi on stock internals with no ignition tuning. It can be done but its not recommended. You won't get the full potential to make power without being able to adjust ignition timing. The ECU does retard timing though with the knock sensor but only to a certain degree. It's not designed with boost in mind and certainly shouldnt be your failsafe.
Emanage + injectors at least!
Old Jul 22, 2006
TheSmuggler's Avatar
Jaryn
May 17, 2016 02:52 AM
HondaGuy7
Feb 22, 2016 01:00 PM
Rodrigo Pizarro
Forced Induction
Sep 6, 2015 03:48 AM
-HondaFTW-
Aug 30, 2015 10:38 AM
justcruzin125
Aug 11, 2015 09:09 PM
