i think i should have done the 30k service
i know most of it was inspection type stuff well right now my gas light comes on at about 250 miles and i drive city highway, its san diego, so you have to take a freeway to get anywhere. its been really hott so ive had the ac on like max, but still 25 miles to the gallon, would changing the atf fluid do anything , ive changed the air filter, had an oil change tire rotation, i guess i should check to make sure my tires are properly inflated, but still 25? what else should i look out for?
Theres only a few things that would have a serious impact enough to cause a mpg to be that low at 30k. my vote is #1, i doubt your o2 sensor and plugs are already bad at 30k.
1. your driving.
2. primary o2 sensor
3. spark plugs
1. your driving.
3. spark plugs
Its alright. Just go easy on that gas pedal. I got 23.8 mpg on my last tank driving very aggressively (I was in a hurry) where my car normally averages 32 mpg. I am estimating that I am gonna get around 35 mpg this time.
Originally Posted by ronaldo9
Also, try cleaning your fuel system. Even though at 30K it shouldn' t be that clogged, it will def improve some gas mileage.
Buy some fuel injector cleaner, the BK44 is good but $$$, there are some decent knockoffs for 1/3rd the price. I usually add this to my car about once a month. Do this a few times and see if this helps.
Make sure to add this when the tank is near empty then fill with gas(to mix it up) for best results. Run the tank down to near empty again.
I would do the atf flush as well which again is $$$ if you have a dealership do it for you.
Originally Posted by runner1738
clean it with what? but my driving hasnt really changed, i mean on my last car i needed new brakes at 30k now both my tires and brakes are doing good, so its just odd how the car feels like its in a slump but i dont really want to take it in and pay 100 or more for inspection
Originally Posted by gearbox
25mpg, is that city? if so thats pretty good i usually only get 22mpg and my car is in great shape (except tranny).
this is happening to me in michigan right now , i just made a thread about it. its really worrying me. i get about 260 and im driving 60 miles of freeway a day... i have 40 thousand miles what is going on.
when i looked under my hood my engine coolant was very low but my car hasnt been over heating, which is good so i filled it up and need to check the level again today and see if its leaking, but that is all i have noticed so far
yea i found that out now that the humidity returned to normal i just returned from a trip where i was getting 36 highway, but not i have to deal with the rock chip in my window
Originally Posted by 2k1_sedan
Hey runner did you make any other changes to your car besides adding coolant? Just curious.
I Hunt Goats, Rams, And Mustangs.
Originally Posted by KINGCHILE
take all the junk you dont need out of your car. extra weight lowers your mpg.
make sure your radiator is working correctly too, the cooler your keep the engine bay the better.
check your tires to see if they are flat or not. i just filled mine up from 20PSI to 32PSI and they feel SOOOOO much better. not to mention in a straight line, it feels alot better when on the gas.
if its just a chip, get that repair kit that stops it from cracking later.
Crayons taste like purple...
Originally Posted by Dticalman81
what will a new 02 sensor do...?? should I get a new one at 77k?
WWJD
Sep 23, 2015 12:56 PM
