i think i should have done the 30k service
Old Jul 19, 2006
runner1738's Avatar
i know most of it was inspection type stuff well right now my gas light comes on at about 250 miles and i drive city highway, its san diego, so you have to take a freeway to get anywhere. its been really hott so ive had the ac on like max, but still 25 miles to the gallon, would changing the atf fluid do anything , ive changed the air filter, had an oil change tire rotation, i guess i should check to make sure my tires are properly inflated, but still 25? what else should i look out for?
Old Jul 19, 2006
ctx66's Avatar
ctx66 will become famous soon enoughctx66 will become famous soon enough
Theres only a few things that would have a serious impact enough to cause a mpg to be that low at 30k. my vote is #1, i doubt your o2 sensor and plugs are already bad at 30k.
1. your driving.
2. primary o2 sensor
3. spark plugs
Old Jul 19, 2006
ronaldo9's Avatar
Also, try cleaning your fuel system. Even though at 30K it shouldn' t be that clogged, it will def improve some gas mileage.
Old Jul 19, 2006
KINGCHILE's Avatar
KINGCHILE is a name known to allKINGCHILE is a name known to allKINGCHILE is a name known to allKINGCHILE is a name known to allKINGCHILE is a name known to allKINGCHILE is a name known to allKINGCHILE is a name known to allKINGCHILE is a name known to all
take all the junk you dont need out of your car. extra weight lowers your mpg.
make sure your radiator is working correctly too, the cooler your keep the engine bay the better.
Old Jul 20, 2006
dalaw's Avatar
Bone Stock!
Its alright. Just go easy on that gas pedal. I got 23.8 mpg on my last tank driving very aggressively (I was in a hurry) where my car normally averages 32 mpg. I am estimating that I am gonna get around 35 mpg this time.
Old Jul 20, 2006
Jrfish007's Avatar
Igot 25 MPG a few times with the CA on too when I had my 7thgen.
Old Jul 20, 2006
runner1738's Avatar
clean it with what? but my driving hasnt really changed, i mean on my last car i needed new brakes at 30k now both my tires and brakes are doing good, so its just odd how the car feels like its in a slump but i dont really want to take it in and pay 100 or more for inspection
Old Jul 20, 2006
2k1_sedan's Avatar
2k1_sedan is an unknown quantity at this point
Buy some fuel injector cleaner, the BK44 is good but $$$, there are some decent knockoffs for 1/3rd the price. I usually add this to my car about once a month. Do this a few times and see if this helps.
Make sure to add this when the tank is near empty then fill with gas(to mix it up) for best results. Run the tank down to near empty again.
I would do the atf flush as well which again is $$$ if you have a dealership do it for you.
Old Jul 20, 2006
ronaldo9's Avatar
I meant what 2k1_sedan said. Buy a fuel system cleaner, not the fuel injector cleaner that doesn't do much. They're like 8-12 bucks in auto shops. You can also have a shop and they can do a full out fuel system cleaning for like 40-60 dollars I believe they run. Even if its not the route cause it will def make the car run alot better. I started buying fuel system cleaner every oil change from 40K and the car seems to be running smoother and accelerating better. Also MPG is very very good considering summer. I drove from my house in NJ to Penn State University (almost 4 hour drive) and had a lil under half a tank doing roughly 80 the whole way with A/C on off and on.
Old Jul 20, 2006
ctx66's Avatar
Before you go and waste any money on fuel system products or an inspection, i'd wait to see if the poor mpg continues.
Old Jul 20, 2006
25mpg, is that city? if so thats pretty good i usually only get 22mpg and my car is in great shape (except tranny).
Old Jul 24, 2006
runner1738's Avatar
its not really city as in stop and go at lights and stuff, its san diego, so we take a freeway to get anyway, i know its summer too, and its been like 105 so the ac has been a lot, but it just feels like there is something wrong or that its slugish, i should check my tire pressure as well, but on the tranny note thats why i feel like changing the tranny fluid, just to hopefully make it last a while, but im getting ready for a road trip so i will be doing a lot of inspections plus i need to have my new rotors and pads installed anyways so i will ave them take a look
Old Jul 26, 2006
marcuse's Avatar
marcuse will become famous soon enough
this is happening to me in michigan right now , i just made a thread about it. its really worrying me. i get about 260 and im driving 60 miles of freeway a day... i have 40 thousand miles what is going on.
Old Jul 27, 2006
runner1738's Avatar
when i looked under my hood my engine coolant was very low but my car hasnt been over heating, which is good so i filled it up and need to check the level again today and see if its leaking, but that is all i have noticed so far
Old Aug 2, 2006
tinman's Avatar
tinman is just really nicetinman is just really nicetinman is just really nicetinman is just really nicetinman is just really nice
In very hot weather your gas mileage will go down. As does the power. You canna cheat the laws of physics, lad.
Old Aug 3, 2006
runner1738's Avatar
yea i found that out now that the humidity returned to normal i just returned from a trip where i was getting 36 highway, but not i have to deal with the rock chip in my window
Old Aug 3, 2006
2k1_sedan's Avatar
Hey runner did you make any other changes to your car besides adding coolant? Just curious.
Old Aug 3, 2006
runner1738's Avatar
nope, unless you count using chevron with techron and driving just highway, but i still have more to do, i still need to change the cabin filters, get an atf fluid change, new rotors and pads, and now i need to fix this rock chip which will probaly come first, hwat kind of places repair glass?
Old Aug 3, 2006
if its just a chip, get that repair kit that stops it from cracking later.
Old Aug 3, 2006
mikem317's Avatar
mikem317 should not be trusted
I'm getting about 32mpg w/ the AC on, 80% highway travel. Sans AC, I'm getting closer to 38mpg. I also drive at a level between normal/aggressive.
Automatic?
Old Aug 3, 2006
TransformedBG's Avatar
I Hunt Goats, Rams, And Mustangs.
TransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of light
junk only starts to really effects gas mileage at 100lbs.
Old Aug 3, 2006
Curiouz_G's Avatar
Curiouz_G is just really niceCuriouz_G is just really niceCuriouz_G is just really niceCuriouz_G is just really nice
check your tires to see if they are flat or not. i just filled mine up from 20PSI to 32PSI and they feel SOOOOO much better. not to mention in a straight line, it feels alot better when on the gas.
Old Aug 4, 2006
shroomster's Avatar
Crayons taste like purple...
shroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to behold
FP60 from lubecontrol.com voila!
Old Aug 7, 2006
runner1738's Avatar
i found a place that will come to me and do it for like 60 bucks so im just to make it easy on myself
Old Sep 2, 2006
Dticalman81's Avatar
Dticalman81 is an unknown quantity at this point
what will a new 02 sensor do...?? should I get a new one at 77k?
Old Sep 2, 2006
shroomster's Avatar
no need to change an o2 sensor untill the check engine light comes on for it....
Matt T
Idle Issues
Sep 24, 2015 04:53 AM
WWJD
Sep 23, 2015 12:56 PM
Jrosa
Sep 14, 2015 08:24 PM
