oil change intervals...
Old May 27, 2006
djc's Avatar
djc
djc is an unknown quantity at this point
i've been told the 2005 7th gens only require an oil change every 10k miles?
so i was wondering how often do we need to change ours? i usually change mine every 5k...thanks in advance!
Old May 27, 2006
shroomster's Avatar
Crayons taste like purple...
shroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to behold
thats fine....every 5k is very good.....
Old May 27, 2006
ctx66's Avatar
ctx66 will become famous soon enoughctx66 will become famous soon enough
i do mine every 7,500 with synthetic. 5k is a good interval.
Old May 30, 2006
S2000man01's Avatar
O RLY
5k with dino shouldn't be a problem at all. synthetic 7500-10k no problem.
Old May 30, 2006
DaddyFatSacks's Avatar
DaddyFatSacks is an unknown quantity at this point
Even driving hard?
Old May 30, 2006
ctx66's Avatar
Yes.
Old May 31, 2006
i do 5-6k but i also use lc20, just wanna be safe.
Old May 31, 2006
CIVIC X3's Avatar
CIVIC X3 is on a distinguished road
damn forealz...i use mobile 1 full syn and change my oil every 4k =(
Old May 31, 2006
S2000man01's Avatar
O RLY
Originally Posted by DaddyFatSacks
Even driving hard?
yes.
if my S2000 can get 5000 miles on conventional oil (and i drive the heck out of it) and 9000 on synthetic, your civic will be just fine.
(i have had UOA's done to confirm that the oil was still properly protecting and working as intended)
Old Jun 1, 2006
HondaSaurusLX's Avatar
HondaSaurusLX is an unknown quantity at this point
Every 10K with full Mobil 1 5W30 synthetic with both my Neon and Civic. If a Neon can last 120K miles and still not burn a drop of oil changing it every 10K, then surely a Civic should be able to handle it..
Old Jun 1, 2006
Thats cool, i'm at 5 now with my Mobil 1. I'm gonna change it soon cause it's getting dark and it was in there during winter.
Old Jun 2, 2006
S2000man01's Avatar
O RLY
the color of oil does not determine when you change it. oil gets dirty. it's supposed to. if it doesn't, then it's not doing its job.
Old Jun 2, 2006
RHCP0801's Avatar
i usually go every 3k with 5w 20 oil, so i guess there is no need to do it that often than?
Old Jun 2, 2006
S2000man01's Avatar
O RLY
no. you can get easily 5000.
the 3000 mile oil change is an old mantra from the past when oils were nowhere NEAR the quality of today's oils.
Old Jun 2, 2006
Jrfish007's Avatar
bad comparison, your neon and civic are econmy cars (I'm assuming you have a civic DX/LX/EX). This civic is an SI, totally different motor, your civic has an economy based motor, an Si has a performance based motor. They are built differently, in short the performance motors will have more blow by than an economy motor, hence eat more oil.
Old Jun 2, 2006
RHCP0801's Avatar
ok good
Old Jun 2, 2006
Jrfish007's Avatar
s2kman is right, if your oil doen't turn dark, it's not suspending the blow by carbon, which means the carbon is getting deposited else where in the engine. oil should turn dark, if you ever take oil out and it looks like new, something is wrong.
mattdoc
Mar 14, 2017 12:10 PM
gearbox
Electrical DIY
72
Nov 27, 2015 08:13 PM
BootyDo
May 7, 2015 04:46 PM
SoNiCcIvIc
Mar 11, 2002 03:37 PM
AnotherDopeStyle
Jan 5, 2002 03:10 PM
