cleaning AEM filter......
Old May 18, 2006
scizod's Avatar
scizod is an unknown quantity at this point
I am due to clean my AEM filter. I just got back from DAP and purchased a K&N Recharger kit which is basically a cleaner and oil. Is it ok to use this recharger kit on an AEM filter or do I have to purchase the AEM cleaning kit? Also, how dry does the filter have to be in order to be oiled up and installed back on the car. Thanks for all your help.
NM.....I found the answer in a different thread
Old May 24, 2006
cwo715's Avatar
Falken Master
cwo715 is just really nicecwo715 is just really nicecwo715 is just really nicecwo715 is just really nice
dont reoil the filter, its known to mess up your IAT sensor and on some cars the MAF sensor, just buy a new filter say the AEM Dry Flo filter. http://www.ajusa.com/cgi-bin/stores/...b2586a7a094af0
Old May 24, 2006
def01tones's Avatar
You bought a used dog??
def01tones will become famous soon enough
alright i just finished cleaning mine right now, so is it safe to throw it back on w/o the oil? or should i put alil bit of oil??
Old May 24, 2006
uh it doesn't filter without any oil. so goodbye engine. just get a better filter, aem dryflow doesnt need oil. K&N/cotton gauze SUCKS for filtering
Old May 24, 2006
def01tones's Avatar
ah screw it! i just wont put the filter back on. filter...psshhh...
Old May 24, 2006
rutscivic's Avatar
rutscivic is an unknown quantity at this point
NO put oil on it.... if you dont thenits pointless, but you MIGHT have to replace the sensor, if you take it off youll see how bad they can get
Old May 24, 2006
burke420's Avatar
The World Is Yours!
i got iNJEN FILTER, and K&N highly rec.s that you re-oil the filter, but a new AEM dryflow wont worry about that. get the K&N cleaner, and follow the instructions.
Old May 24, 2006
diskreet's Avatar
Oil it dude. If you do it right there should be no reason for it to do harm!
Old May 24, 2006
shroomster's Avatar
Crayons taste like purple...
shroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to behold
oil goes and gets burned up no harm no foul...just follow directions and don't over oil...thats how ya screw up sensors and IAC valve....
Old May 26, 2006
D17thgen's Avatar
D17thgen has a spectacular aura aboutD17thgen has a spectacular aura aboutD17thgen has a spectacular aura about
i have had an aem sri for 33k miles and cleaned it twice already.
instructions asks to re-oil with a coat over every piece of the filter. i did double coats on both times and havent had a problem. what i did was shake the filter to remove any "loose" oil. if anything dripped, then i know i used too much oil. afterall, they purposely added red dye to the oil for a reason...
if you read the instructions, it clearly states you must re-oil the filter.
Old May 29, 2006
reddawnman's Avatar
reddawnman is a name known to allreddawnman is a name known to allreddawnman is a name known to allreddawnman is a name known to allreddawnman is a name known to allreddawnman is a name known to allreddawnman is a name known to allreddawnman is a name known to all
easy does it...
Yeah, the reason you get messed up sensors and such is being overly enthusiastic with the oil. The thing should be reddish purple when you look through the light... if you see a really really dark purple (or if you spin it and get coated in goop) you used too much. i oiled the "top" (closest to the outside of the circle) part of the filter and kind of let it seep down, then I turned the filter 90 degrees and continued. repeat until its coated. then, and only then, did I add more oil to the whitish looking areas after i saw how it seeped in. works pretty well, although there seems to be constant debate over whether K&N's filter worth a damn. Thats another issue entirely...
Hope that helps
A
Old May 29, 2006
sil04ver's Avatar
sil04ver is an unknown quantity at this point
Anyone know what size dryflow I need for my v2?
Old May 30, 2006
12345678910's Avatar
12345678910 is an unknown quantity at this point
the jerkoff who changed my oil last week said to oil my filter. im not now, im too paranoid about my car, haha
Old Jun 2, 2006
depotcivic's Avatar
depotcivic has a spectacular aura aboutdepotcivic has a spectacular aura aboutdepotcivic has a spectacular aura about
I just cleaned my sri aem and did as they instructed. When I oiled doe, I oiled to much....That shyt was dripping oil everywhere. I let all the oil drip out till I seen no more coming off the filter before putting on. Looks good now and can notice the power gain I had lost from not cleaning it since I bought it.
carid
Nov 7, 2015 01:46 AM
wingsfan19
Oct 1, 2015 03:45 AM
Sep 27, 2015 11:33 AM
thaler4cuse
Sep 7, 2015 08:25 PM
naokigoffi
Aug 30, 2015 06:19 PM
