2nd mod need help
I just bought a autometer 5" tach with shift light. I searched and did not see any DIY on a install.... can someone help me I dont like to cut or drill without getting advise and everyone was helpful with the short ram intake.
Please help a noob out
Late
B
Late
B
here yah go start here: http://www.autometer.com/tech_installation.aspx hope this helps.
I need TP for my bunghole
the link doesn't work
Use this link or just read below: http://www.7thgencivic.com/forums/sh...d.php?t=155253
Installing a Tach
These are the wires that the author used.
Red line > I put to the 3rd fuse in dash
White line > I put to the right headlight fuse under the hood
Black line > To the chassis as close as possible to the tach
Installing a Tach
- The four wires from your aftermarket tach are red, green, white, and black.
- The red, white and black should be easy. (See below for suggestions)
- The green wire goes to your test tach wire located by your battery. It looks like a coupling just pull it out and the blue wire is exposed use the green line off the tach to that.
ricer_em2
May 11, 2016 08:09 PM
Touge
Sep 22, 2015 11:55 PM
Touge
Ottawa
Sep 22, 2015 11:52 PM
