2nd mod need help
Old May 12, 2006
civicism's Avatar
civicism is an unknown quantity at this point
Question 2nd mod need help
I just bought a autometer 5" tach with shift light. I searched and did not see any DIY on a install.... can someone help me I dont like to cut or drill without getting advise and everyone was helpful with the short ram intake.
Please help a noob out
Late
B
Old May 12, 2006
SloCol-Vtec's Avatar
SloCol-Vtec is an unknown quantity at this point
here yah go start here: http://www.autometer.com/tech_installation.aspx hope this helps.
Old May 12, 2006
PunkingCivic's Avatar
I need TP for my bunghole
the link doesn't work
Use this link or just read below: http://www.7thgencivic.com/forums/sh...d.php?t=155253
Installing a Tach
  1. The four wires from your aftermarket tach are red, green, white, and black.
  2. The red, white and black should be easy. (See below for suggestions)
  3. The green wire goes to your test tach wire located by your battery. It looks like a coupling just pull it out and the blue wire is exposed use the green line off the tach to that.
These are the wires that the author used.
Red line > I put to the 3rd fuse in dash
White line > I put to the right headlight fuse under the hood
Black line > To the chassis as close as possible to the tach
Old May 17, 2006
Exmashin2355's Avatar
Exmashin2355 is an unknown quantity at this point
take your time on it the link above works...dont go drillin a buncha holes in the car...impossible to sell after that...heh
UltraHDGames
Jun 8, 2016 05:16 PM
ricer_em2
May 11, 2016 08:09 PM
Michael Durkin
Transmission
Sep 24, 2015 12:35 PM
