Electrical issue...ugh
Old Apr 24, 2006
blouisgod's Avatar
Life Begins > 6800rpms
Question Electrical issue...ugh
58k 2k1 EX
As Im driving and car is at normal temp, if I turn on the a/c, there is almost a type of glitch in all electronics:
radio goes out and comes back on
abs light comes on
gauges tweak
car sometimes cuts out and stalls if im going slow enough
Im thinking a relay may get hot and draw to much or something, im not sure though. any ideas? thanks
Old Apr 26, 2006
blouisgod's Avatar
anyone have any issue like this?
Old Apr 26, 2006
CraigW's Avatar
Bad ground connection at chassis ??
Old Apr 29, 2006
blouisgod's Avatar
checked em
Old Apr 29, 2006
ms652681's Avatar
ms652681 is an unknown quantity at this point
Sounds to me like some kind of alternator/battery problem. I had a similar prob. with a car of mine years ago and it was bad alt.
Old Apr 29, 2006
that ac is too much strain for the car man. sorry that was no help idk, is the engine light on?
Old Apr 30, 2006
CraigW's Avatar
You could try to hook up a volt meter to get a better idea of whats happening. If the battery is weak or the charging is not up to specs.
Is it the original battery ??
Old Apr 30, 2006
ya it sounds like a damaged or drained battery. when the ac kicks on, it draws alot more than what the alternator provides. so everything must switch to battery power, which if less than 11-12v, stuff starts dying.
Old Apr 30, 2006
TeLLy's Avatar
Yes, it's an Acura EL
I was driving to work one day last year and my old battery terminal clamps were loose. I hit a bump and the positive terminal came off the battery so EVERYTHING was running right off the alt. My voltmeter went nuts, reading as high as 18v. My gauge cluster went equally crazy, the needles were bouncing everywhere and all the indicator/warning lights came on. The stereo turned off and on, off and on, and even the carputer was rebooting. Then I slowed down for a stop and the car stalled before I could even come to a full stop. After I reconnected I was fine.
All that said, check your fuses, alt, and battery, and make sure no connections are loose or corroded.
cferry7
Oct 18, 2015 06:32 PM
Solo Flow
Oct 4, 2015 07:52 AM
thebmillz
Electronics
Oct 2, 2015 08:38 PM
Bruce2
Sep 27, 2015 08:45 PM
beanhead
Sep 24, 2015 12:04 PM
