Help !!! stuck on installing revo ss
how do you take out the primary cable? i'm talking about the metal retaining clip.
here's the pic, it's the red arrow one
What happened to this forum?
If you read my diy from where you got that picture from you would know that you have to pry it out carefully. At least that's what I did. There may be some other way. But that's what I did and it is still working today
Here ya go!! Linkers
is it glued or something? i've been trying to pry it out for like an hour and it won't come out.
did you do it from the backside of the metal retainer? of from its side?
Take a small flat head screwdriver and put it on the top edge (where the arrow is pointing to) and hit it in there. It is like a spring clamp. Once you get the clip off, push in on the cable and pull it out. The cable on the left turn it counter-clockwise ( toward drivers door) It will roll out. Hope that helps ya.
Originally Posted by ncirom2003
yes, cables must be dettached for revo install, then reattached.
Grey's bushing kit is supposed to fix the noises. It's basically just new washers and clips to replace the factory ones that get loose after all the prying and loosening. I don't even think he is around anymore.
Originally Posted by Spracto
there is an ad on 7thgen for "precise shift" shift bushings. anyone have them? are they good? cause i need some bushings hardcore. i have the DC sports SS and its real stiff.
Drunken Master-7thgen Ninja
i got the bushings and the capyoda kit too with my SS i love it! anyway, flathead screwdriver on the bottom. it took me like 30 minutes to do it carefully so i wouldn't crack the stock shifter. i thought the left cable was harder. update it
Bill in San Jos
Jul 10, 2015 12:32 PM
JustaRhymez
General 7th Gen
Jul 10, 2015 07:12 AM
ballmich
Jul 9, 2015 11:59 AM
now i guess i just have to deal with it
