Anyone know about Ignited Switches??.. need help..
Old Apr 7, 2006
mikemal's Avatar
mikemal is an unknown quantity at this point
I picked up a couple of these and they have an LED light at the end, made my Ignited. Basically i can assume the wires will be put on in an "in" and "out" fashion at the bottom part but i am curious as to whether the piece on the right should hook up to a power supply or whether this is a ground for the LED, but in that case what would power the LED?
also... i bought 16ga wire to extend this with my engine start button and ignition. i have it figured out how i will be wiring it but will this gauge work?
thanks a lot, i appreciate it.
Old Apr 8, 2006
cleancivic 05's Avatar
cleancivic 05 should not be trustedcleancivic 05 should not be trustedcleancivic 05 should not be trustedcleancivic 05 should not be trustedcleancivic 05 should not be trustedcleancivic 05 should not be trustedcleancivic 05 should not be trustedcleancivic 05 should not be trustedcleancivic 05 should not be trustedcleancivic 05 should not be trustedcleancivic 05 should not be trusted
rtfm naw just joking look on there website
Old Apr 8, 2006
paradoxblue's Avatar
ok look on the swithch. u will see the three poles. the one out of place near the front is the ground. you need to groudn this one for your led to work.
then you run power to the power post. it may be a lil light or something. and then out to the light itself.
as for how the other two are labeld. im not 100% but i do know i had to ground the mystery pole on mine.
Old Apr 14, 2006
diskreet's Avatar
Always use a push button, momentary on (usually push to make), switch so that if you have to stop starting you just let go.
kaashifv
Interior
Jul 27, 2015 05:28 PM
sch2cm
Jul 21, 2015 09:58 PM
emich
Jul 20, 2015 08:42 AM
cukaracha
Jul 17, 2015 05:48 PM
jody501
Jul 10, 2015 11:01 AM
