RSX trailing arm
Old Apr 6, 2006
cerebrous's Avatar
cerebrous is an unknown quantity at this point
RSX trailing arm
Have a 01 LX with NO sway bar therefore no sway mounting bracket on the Trailing arm
Can I get a RSX trailing arm and slap it on there so I have the mounting brackets?
Old Apr 6, 2006
Zzyzx's Avatar
Autocross Junky
They may fit, but why not just buy an EX's trailing arms?
Old Apr 6, 2006
cerebrous's Avatar
I can't find the EX trailing arms for cheap....
Found a set from the RSX
Just remembered one thing the brackets for the rsx trailing arm is better.. RSX struts have bigger bushings out back therefore bigger bracket on trailing arm.
This means oem civic rear bushings will be loose there..
Old Apr 19, 2006
cerebrous's Avatar
hrm bump
Old Apr 20, 2006
CivicMexicano's Avatar
El Pinche Turbo Mexicano
CivicMexicano is an unknown quantity at this point
Any one know if the Fron LCA's form a DC5 Type R would fit our civic??
Old Apr 20, 2006
Touge Whore's Avatar
K-DUB
Touge Whore is an unknown quantity at this point
Buy Ex trailing arms, because the RSX lower bracket on the arm is slightly larger. You won't be able to use your Ex setup you have now. Yes, the FULL DC5 ITR setup works on our car....I have them on mine. Refer to my thread, http://www.7thgencivic.com/forums/sh...d.php?t=254014
jackoncruzpr
Sep 29, 2015 07:59 PM
PunX
Sep 23, 2015 10:45 PM
bashea
Sep 15, 2015 04:59 AM
First Car
Sep 8, 2015 08:54 PM
muttleytm
Jul 14, 2015 05:31 PM
