RSX trailing arm
RSX trailing arm
Have a 01 LX with NO sway bar therefore no sway mounting bracket on the Trailing arm
Can I get a RSX trailing arm and slap it on there so I have the mounting brackets?
I can't find the EX trailing arms for cheap....
Found a set from the RSX
Just remembered one thing the brackets for the rsx trailing arm is better.. RSX struts have bigger bushings out back therefore bigger bracket on trailing arm.
This means oem civic rear bushings will be loose there..
Buy Ex trailing arms, because the RSX lower bracket on the arm is slightly larger. You won't be able to use your Ex setup you have now. Yes, the FULL DC5 ITR setup works on our car....I have them on mine. Refer to my thread, http://www.7thgencivic.com/forums/sh...d.php?t=254014
jackoncruzpr
Sep 29, 2015 07:59 PM
PunX
Sep 23, 2015 10:45 PM
muttleytm
Jul 14, 2015 05:31 PM
